Page 1 of 11 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 1 to 10 of 105
Thread: Fast eddies green driftering ae86
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    I bought this thing back in 2004 stock orange defected for $ 1700 and started drifting it with a ze king springs and stock wheels.
    been through many engines since, was purple for one round then green then sparkly green and now heres as it sits owing me over $50k.
    list of mods
    Repainted Kawasaki green with PPG prismatek on top.
    BODY WORK
    Custom made radiator support
    HKS R32 gtr alloy radiator
    Twin 14in thermo fans
    Grex oil cooer and oil filter relocator
    Custom alloy radiator overflow tank
    Custom alloy catch can
    Rising rate fuel pressure reg
    Custom intercooler pipes and rocker covers painted in morpheous metalic
    Seam welded engine bay with tower supports to firewall and chassis
    strengthening steel plates
    Bonnet pins and hatch pins
    No name brand engine torque dampner
    Cams approved full roll cage
    Sparco racing Seatsx2
    New harnessesx2
    Custom alloy door trims painted black with ppg prismatek
    Alloy centre console with fuse box and battery isolator switch
    Spare wheel well removed and flat plate put in place
    Alloy racing fuel cell
    Complete new wiring of lights and windscreen wipers using AE86 standard switches
    Jun-bl rear stainless cannon
    Full face Jdm AE86 tail lighs with custom blackout
    Origin front bar
    ENGINE/DRIVELINE
    Sr20det engine blacktop s13
    Na cams
    adjustable cam gears
    Rocker stoppers
    ARP head studs
    4 layer cometic metal hg
    custom fuel rail with fuel in both ends and out the centre
    t28/71 garret with .64 rear housing
    k+n pod filter
    aires forged pistons
    h-beam rods
    acl race bearings
    greddy style alloy sump
    Sr20det bellhousing rb20 gbox
    Extreeme clutch and flywheel
    New Bosch 044 fuel pump and 2 x lift pumps to 4.5l alloy catch can
    Deka dry cell battery
    Custom FAST EDDIE hydraulic handbrake
    F series tarago diff housing spacia 4.3 centre new bearings and seals
    R31 discs
    Jdm AE86 rear calipers on pedal brake
    R31 calipers for handbrake
    SUSPENSION
    front
    ae86 cusco camber tops
    hsd s13 coils
    8kg springs
    no name brand jap shortened s13 knuckles
    sr20det brakes
    custom ae86/s13 lcas
    buddy parts tie rod ends and custom thread tubes
    custom modded engine crosmember rack moved 30mm foward
    rear
    6kg springs
    whitelne swaybar
    kyb shocks
    RIMS/TYRES
    front 15x7 0 offset riversides
    rear 15x7.5 -5 offset preciedos
    15x7 -2 offset ssr mk2 coppies
    15x7.5 0 offset dragway convo pros
    AE86 THE BEST
    Eddie
    sa
    Things to do before it hits the track for g1 09
    rear bar and skirts
    screamer pipe
ID:	1330   Click image for larger version.
ID:	1331   Click image for larger version.
ID:	1332   Click image for larger version.
ID:	1333   Click image for larger version.
    AE86 THE BEST
    Sherlock
    This thing sounded so tuff last time I heard it at the track. Got any good pics of your engine bay? I'm interested in seeing some of the work done to it
    Eddie
    sa
    not on this comp mate will post up when im home
    AE86 THE BEST
    Veteran shift_rook's Avatar
    SE Burbs
    dude the riversides ars sick! very nice car. get the vids crankin
    Eddie
    sa
    heres a pic of the engine bay last season ill put up a new pic when i get the engine.
ID:	1368   Click image for larger version.
    AE86 THE BEST
    E-Famous (Remeber your roots)
    Purple is hot.
    Love the riversides! car looks good, vids would be sweet
    get out the way wimmenz im trying to look at the car
    Eddie
    sa
    heres a few engine bay shots made a new pipe for the air filter so it sits out in the open, also made a screamer dump off the turbo so its fair loud and cant keep boost under 20psi lol.
    Got a pic of the modded fuel rail that the fuel goes in both ends and exits out the centre. Making a new pipe from cooler to plenum that flows killer not like the old angled one i had.
    Recently got the engine back and tuned got hbeam rods 4 layer hg arp's all round and na cams and adj gears, for some reason im cursed to have no power and to cut a long story short and a long day of farking around on the dyno we put the turbo cams back in and set gears to 0 and it made 197kw on 20psi which is about 30kw down on what it should be.
    but had it at practice on saturday and it went killer.
    My modded engine x member with the rack moved foward and the shortened knuckles worked farking killer had no problems with the steering at all now and ran re001s on the rear and it is realy fast now,
ID:	1670   Click image for larger version.
ID:	1671   Click image for larger version.
    AE86 THE BEST
  1. Fast eddies no3 ke70 siiiiiiiiiiik
    By FAST EDDIE in forum KE70 / AE71 Owners Forums
    Last Post: 29th June 2012, 07:11 PM
  2. Fast eddies first 4x4
    By FAST EDDIE in forum Other Rides
    Last Post: 19th June 2010, 04:15 PM
  3. Fast eddies ke70 shiiiiiik
    Last Post: 14th May 2009, 11:51 PM
  4. FAST EDDIES KARAZEEE KAWASAKI GREEN 86
    By dog89 in forum AE86 Owners Forums
    Last Post: 3rd October 2008, 06:11 AM
  5. FAST EDDIES NEW SHOW
    By orangechargd86 in forum AE86 Owners Forums
    Last Post: 8th May 2007, 02:35 PM
