I realy like the methods of using a one meter long entension to get the top two bolts out. Use ratchet spanners for the block to bellhousng support brackets. Drain oil, drop tailshaft, take console out, shifter off, remove earth lead before doing anything else.
you know there may be a slim possibility of pulling the boot of your clutch fork and seeing what flywheel you have through that hole
