Results 1 to 8 of 8
Thread: For Sale - 4A-GE Short Motor - Brisbane
    Simon
    Bowen Hills
    Default For Sale - 4A-GE Short Motor - Brisbane
    I have a newly rebuilt 4A-GE short motor for sale. Details are:
    • Standard 3 rib 4A-GE block with 40mm con-rod bearing crank.
    • Block was bathed and cleaned, bored 0.5mm over size, honed and decked with new Welsh plugs installed.
    • New 0.5mm over sized pistons, rings and gudgeon pins.
    • New main bearings and con-rod bearings.
    • New rear oil seal.
    • New oil pump assembly and front oil seal.
    • New water pump.
    • New timing belt idler.
    • New oil pressure sender.
    • New magnetic sump plug.
    • All new gaskets.
    • Comes with head gasket and complete head gasket kit.
    Price: $700 ono - SOLD
    Phone Simon on 0407 462 367
ID:	1335   Click image for larger version.
ID:	1336   Click image for larger version.
ID:	1337   Click image for larger version.
    West
    ke70dave would love this.....
    dave..
    where are you!?
    Dave
    where do you live mate?
    sorry sais brisbane.
    might be very keen hey will do some $$$ calculations and get back to you.
    do you have reciepts for the work done?
    also what brand pistons and bearings have you used?
    性交を愛する
    Pm sent.
    Seamus
    Milton
    that's an excellent deal
    Simon
    Bowen Hills
    Ke70dave,
    I have receipts and boxes the parts came in for most things.
    The pistons, rings and gudgeon pins are NPR.
    The small end bearings are ACL Duraglide.
    The big end bearings are ACL Aluglide.
    The thrustwashers are ACL.
    The oil pump assembly is genuine Toyota.
    The gaskets for the oil pump assembly, rear main seal assembly, oil strainer and front main oil seal are genuine Toyota.
    The rear main seal is a Repco replacement part.
    The water pump assembly is a Repco replacement part.
    The timing belt idler is genuine Toyota.
    Don't have the receipts for the maching work but I can get them off Hagens on Pickering St who did the work.
    hey mate just tried to send u a msg i sent it to the number u got there and the guy said wrong person.
    any way im keen as but i really only need the block u wiling to separate?
    Simon
    Bowen Hills
    Sorry I screwed up my number is 0407 462 367.
  1. (QLD) 4A-GE 20V Blacktop engine for sale
    By luke111 in forum Car Parts For Sale
    Last Post: 17th July 2012, 09:38 PM
  2. 1gr short motor for sale
    By sideburns in forum Car Parts For Sale
    Last Post: 21st June 2012, 08:58 AM
  3. 4A-GE long block, hobart. Or motor for rebuild
    By Jonny Rochester in forum Cars or Parts Wanted
    Last Post: 12th March 2009, 12:19 PM
  4. 4A-GE starter motor help
    By 16-4AGE in forum Technical - Questions
    Last Post: 18th February 2009, 01:09 AM
