Results 1 to 2 of 2
Thread: Cometic Head Gasket
    Senior Member slideways's Avatar
    Tristan
    Default Cometic Head Gasket
    I have a cometic mls metal head gasket, that was on a 4agte. After about 5 mins of run time the head was pulled off.
    Now the question is, can i re-use the cometic gasket?
    I have read in a few places that these gaskets can be re-used and then some people have said not too ever re-use a head gasket.
    If i can't what head gasket should i go for?
    Its also the higher comp gze.
    Member filfilfil's Avatar
    Phil
    Just South
    There is a fair bit of crush when torqued down and this is aligned to the last position, not sure its worth the risk?
    I myself wouldnt but just depends on the hassle if it doesnt seal and you have to do it again. Use Hylomar if you do....
    Given the price of a new one I can understand wanting to reuse it....give them a ring to confirm.
    I have a new TRD 0.5 if you are interested.
    Cheers Fil
  • Similar Threads
    1. Replies: 17
      Last Post: 4th April 2012, 04:12 PM
    2. Head gasket
      By Hazzard in forum Technical - Questions
      Last Post: 27th October 2009, 10:33 PM
    3. 4AG Cometic head Gasket 1mm (decompression plate)
      By craigy in forum Car Parts For Sale
      Last Post: 24th February 2008, 08:56 PM
    4. 4age ARP Head stud Kit, toda 0.8 mm head gasket
      By rxbenny in forum Car Parts For Sale
      Last Post: 10th July 2007, 11:50 PM
