Results 1 to 6 of 6
Thread: Handbrake assembly
    Veteran bigm's Avatar
    Gold Coast
    Default Handbrake assembly
    Hey Guys
    Well me being me, pulled apart my drum hand brake assembly in the MX73,
    Does anyone have a diagram of how they go back together.
    I get the basic principle, but not sure on the order and what not.
    A diagram from any disk overdrum setup would help i imagine
    Senior Member Dylan's Avatar
    Dylan
    Did you pull apart both sides? If you've only done one side use the other as a referance
    Gold Coast
    i did pull apart both sides...
  • #4
    Veteran driftke70's Avatar
    Ryan
    Buderim
    small spring at bottom
    adjuster sits in the little [ ] shaped nook the shoes make
    big spring goes over or above adjuster
    pins go through the back towards the outside of the car and twist locks on
    gently hold open while you get the cylinder in
    rinse the whole lot with slightly soapy water
    slacken handbrake cable right off at the lever inside the car
    wind adjuster so that the drums only just go on and when you turn the axle you can only hear the faintest of rubbing noises
    take up slack under the car
    fine tune at lever inside car.
    drink beer.
    wheelfriends.wordpress.com
  • #5
    Junior Member YRO 11A's Avatar
    Feb 2013
    Peter
    ACT
    Tuggeranong
    I know this is an old thread but i believe this is exactly what your looking for.
  • #6
    Mar 2011
    Ali
    dead link?
  • Similar Threads
    1. anyone looking for a job doing automotive assembly?
      By NIZLAH in forum Brisbane & QLD Events and Discussion
      Last Post: 29th September 2012, 07:24 PM
    2. Tophat Assembly
      By GOODY in forum Technical - Questions
      Last Post: 17th July 2009, 12:24 PM
    3. WTB AE86 Handbrake Lever Assembly
      By Medwin_3sGTE_AE86 in forum Cars or Parts Wanted
      Last Post: 7th March 2009, 02:13 PM
    4. S13 brake assembly
      By paulie in forum Car Parts For Sale
      Last Post: 25th June 2007, 06:54 PM
