Results 1 to 10 of 18
Thread: Radiator options?
    Senior Member 45aken's Avatar
    Marko
    Default Radiator options?
    ok i have a non stock radiator in my 86 now, i think its an ae82 i have forgotten.
    basically asking what everyone else is running, and i want to aim towards a car i can easily get new/aftermarket parts from eg s13, r32 etc.
    making top rad mounts is easy, but i would be hoping for something that will slot into the bottom mounts without to much drama.
    photos would be great too
    Veteran shift_rook's Avatar
    SE Burbs
    ah hyundai twin thermo? that's what my mate's running. hasn't had the motor running for to long so can't tell you how good they are. got one with all pipes and twin thermo's for bout $100 from the wreckers
    Marko
    yeah i know about that,
    looking to get something aftermarket like a koyo but figured if i could get something bigger from another car +alloy koyo that things would be better.
    thinking s13, r32, etc
    SE Burbs
    ah ok, i getcha. nah no help i'm afriad, but i'm gonna try with some form of aftermarket s13 rad for my car.. if you want to wait about a year i'll tell you then haha
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    s13 wont fit i tried that it sits to high over the bonnet
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    Quote Originally Posted by Fozz View Post
    are the 86 nose shorter then ke70s?
    i got a s13/r32 one in my car, its mounted abit back because of my intercooler but wouldnt have any problem with it mounted normally
    I've used the Rad out of a Camry, they come 2 core stock, and it's bigger than the 86's. I know it's the V-6 model, I dont remember the year though. I think it was a 1996. It's been awhile.
    Reeece
    Casula
    koyorad 52mm twincore OEM only one i would use...
    c
    st162 rads are really good. I bolted the st162 bottom mounts to the front of the 71 and use the top ones bolted to the rad support. Comes with twin thermos with a good shroud never seen it get hot.
    Davey & Riki-lee
    South Australia
    Seaford SA
    il be using some quad core thing with both outlets on the drivers side from a land rover lol
    il get more info when i get it
    Our introduction - Click here
  1. Replies: 3
    Last Post: 11th June 2012, 08:22 PM
  2. Replies: 2
    Last Post: 9th March 2011, 03:41 AM
  3. Engine Build - Valve Options - Bearing Options - Head Gasket
    By hitoriko in forum Technical - Questions
    Last Post: 19th September 2009, 05:59 PM
  4. Radiator/cooling options for the AE86
    By Driftspec in forum Technical - Questions
    Last Post: 17th September 2009, 11:38 AM
  5. coilie options
    By jinjaninja in forum Technical - Questions
    Last Post: 17th March 2008, 10:39 PM
