I've switched from using coolant(anti-freeze/anti-boil stuff) to distilled water and . Straight distilled should be fine but I put corrosion inhibitor in for some peace of mind.
Car - AE86
motor - 4A-GE
use - circuit racing
Is it OK to use Castrol corrosion inhibitor or do i have to buy the genuine Toyota stuff?
"There is only Bathurst, the rest is just waiting." Allan Moffat.
just dont mix different types (Red/green) and youll be right with anything.
i used to use those little cans of inhibiter, dad is a big fan of them, but then i started buying the bottles of coolant (5L ones that react to UV light!!) and never looked back.
- Blaise Pascal
give it a good flush and run toyota red.
MY AE86 BUILD
yeah toyota red is good but better than all that for the track is distilled water and a small bottle of redline water wetter.
I have heard and seemingly experienced something like distilled water causing more corrosion than tap water. I used to use $5 Clean team pre-mix, worked well. I want to now run a sacraficial zinc annode.
$6 autobarn premix
I have used Toyota red Longlife Colant and Denineralised water for20 years without an issue. Pulled the head of my Landcruiser a year ago and the alloy was like new without the slightest amount of corrosion. This is the safest way to go if you want to spend a couple of dollars more.
Toddw
