into it son!
Text Changes
I bought this Ae71 with the sr20 not long ago but wasnt happy with it so ive taken all the running gear out and doing a swap over into my 82 ke70
Heres a list off wats done to the car wen i bought it
engine : S15 sr20det , arias 40thou over sized pistons , scat H beam steel rods, clevite77 bearings threwout, minor mods to oil pump and oil galleries, 70 thou (1.7mm) cometic steel head gasket, head is mildly ported non polished, everything balanced and wot not, lash adjusters have been moded, heaveir double valve springs, cams head studs etc
custom steam pipe manifold heat rapt, carrying a Gt3076DBB turbo with a 44mm external gate, braided oil and water lines.
Autronic SM4 is the brain for the engine,
Orc super single clutch kit and steel flywheel, behind that is a s14 5speed box , custom 1 piece tailshaft , R31 shortened LSD diff with billet axels billet bearing ends etc, Vl turbo pick up pump into surge tank in boot then a bosch motorsports high pressure main pump feeds the engine thru a 10mm feed line and 8mm return customised to fit ae71, brakes are standed disk r31 rear with working handbrake, and front is F6 typhoon 328mm disk rotor fitted with a Vx v8 holden caliper, struts have coil over kits fitted with king springs, rose jointed adjustable trailing arms and rose panhard adjustable rod, rays 17x7 upfront 17x8 on rear, pajero 1inch brake master cylinder to pull the car up!
messy engine bay
started strippin
all the running gear is gettin transfered into this rolla
New pics stripped engine bay
Started rubbing down the engine bay today & hifilled
into it son!
shouldll be good with the 3037 and big TB.... subscribed
Engine bay got painted today also installed HKS cams and and a set off rocker arm stoppers![]()
Wow, engine bay looks sweet. Battery in boot?
you clearly dont fuck around, nice work
Nice toyo badge on the r/cover.. lol
thanks mate yeh the battery is in the boot
should slide like no tommorow
