should be able to get one off an ae82 fwd 4age, wreckers have them
Car - trueno
motor - 4age
use -driving
problem -tps is stuffed and cant find one the same...yet
occurs/started when - i bought the car...i think
personal situation - want/need it running better and cant find the info im looking for.
ok well the tps on my bigport has shit itself awhile ago (rough idle, running rich, fair bit bogy when the foot goes down).
so i thought i'll buy a bigport tps off some one and when it turned up today it was different.
the prong insert thing or whatever its called, on the sensor i bought is horizontal and mine is vertical (not exactly).
took some pics but forgot to pics ofthe throttle side of the sensor.
mine.
bought one.
together.
can some one help?
sorry bout pic size......again
cheers jamie.
Never loose respect of what your doing behind the wheel!
~KEEP DRIFTING FUN~
cheers mate ill go have a look tomorrow
thats if you have a bigport 4ag in your 86
~KEEP DRIFTING FUN~
TPS's go like this
Jap TPS off 4A-GE: same between FWD and RWD
Aus TPS off 4A-GE: not the same as Jap/actuator sits the other way.
What you need is BOTH the TPS AND actuator off whatever car. I think I have a good jap TPS and butterfly lying about somewhere.
fuck i went through this not long ago, mega hassle! do a forum search, i ended up working out what cars had what codes. i couldn't find one anywhere and got stuck with a $200 bill from toyota... and now i have a spare!
What you haven't said is whether you have adjusted the TPS as per factory. Do that first.
