abit unrelated i know, but scince were on the topic of beams and tachos
how can i get my standed ae86 tacho working with the adaptronic?
i tryed conneting the ign3 to the tacho but no go?
do i have to tap into an ign wire on a coil?
you can adapt the speedo cable from a W55 onto an Aisin 6 speed?
The rest seem reasonable enough.
SO any clues on the fly by wire? will it crack it when you manually control it like the way the BMW's do?
theres a sneaky trick using a relay coil to get the right high voltage pulses. I think you put the coil inline with the signal or something.
Clay, search toymods for tacho booster. There is also the option of buying an MSD 8920 tach adapter or dakota digital SG something or other. I'm going to try and go the modified circuit board route... I just hope it works out .
Sam, if using the stock intake manifold/fly by wire it's fairly simple. The throttle body has 2 sensors, one for pedal position which utilizes a standard style cable attatchment and a second for butterfly position controlled by a motor. It's all integrated/mounted to the throttle body itself, just find a cable that fits (or make one). The rest is controlled by the ECU.
Andrew
wow how strangely easy, thanks Andrew
well there ya go.... told you there was a clever person
06/07/2011
so any tips on how to adapt a mechanical cable to the Aisin 6 speed box?
hmmm gunna be interesting making one of them
is it as simple as using a worm drive gear from a w5x and cable from a w5x box?
any W, R or C (fwd corollas) driven gear will work in the 6 speed, matching gear starts and ratios aside
Yeah the DBW system is half cable as a failsafe, Toyota treaded carefully in to this field. Didn't help in the end though. THis makes integrating it fairly easy as you dont need a sensor on the pedal etc.
For the tach booster Clay, I would suggest modding the tacho board to reduce its operation voltage as Andrew suggested. Theres a how to floating around. Alternatively, witzls circuit from toymods works pretty well.
^ what he said. Use the W5x mechanical drive in the transmission end. The end of the most toyota mechanical speedo cables is exactly the same. For instance my AE86 cable fits the W58 drive with no modifications.
Andrew
