Page 19 of 40 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... LastLast
Results 181 to 190 of 400
Thread: Universal 3sge (inc Beams) into AE/KE thread
  1. #181
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    or you can use the factory sprinter one, and modify the outlets on the motor slightly.
    Andy
  2. #182
    Jan 2011
    Aram
    Noord-Holland
    Haarlemmermeer
    Netherlands
    A guy in Holland uses a Volkswagen Santana radiator, maybe I will have one made, not sure yet.
  3. #183
    Veteran AJPS's Avatar
    Lonsdale
    as for why some people dont use the j160 apart from tunnel
    Cost - j160 about $1100
    W57 with bellhousing and everything $500
    Gearset availability etc
    and also some motorsport categories not allowing 6 forward gears
  4. #184
    Anthony
    sorry I missed this. My own car ran the 6 speed so I just ran a stock altezza starter. for W box version i found a compact solution to be a 20V starter as mentioned, with one of the two mounting ears cut off and rewelded another 30degrees or so around the base. not too hard to do with a bell there as a jig to tack it up. At that stage 20V starters were literally laying on the ground (I was wrecking a lot of FF front cuts for engines etc) so they were a logical choice. 7AFE etc should be similar I think. It's the high torque starter with the two thin external bolts running the length of the motor. I've found these to be the best of the 3 common toyota starter motor styles.
  5. #185
    Andy
    Adelaide Hills
    What are some other alternatives to use as rubber engine mounts instead of the factory Altezza ones? Mine both tore apart out after one meeting, and the fluid out of them went all over everything. Someone was saying that supra ones are a similar size and have the pins in the same spot, but have a complete metal casing around them to stop them splitting.
    Any suggestions?
    EDIT:
    something like these would be perfect (yes I know they are TRD ones):
    Andy
  6. #186
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    These are the JZA80 VVTi ones that i was telling you about.
    Same sizing as MX83 mounts.
  7. #187
    Sep 2009
    Ryan
    Qld
    I used mounts from a Holden Adventura (v8)
    They are similar to the factory Altezza (rubber cylinder style) except are taller.
    This helped me get clearance over the KE70 crossmember (in my RA23 Celica)
    The mounts attach to the factory cast alloy mounts on the engine side of things, then they sit on top of some steel channel welded to the top of the KE70 crossmember (about 20-30mm high)
  8. #188
    Andy
    Adelaide Hills
    Are those Holden ones fluid filled? How much taller are they? I am guessing they have a single stud on the bottom of them
    Andy
  9. #189
    Sep 2009
    Ryan
    Qld
    Not fluid filled as far as I'm aware.
    Single stud top and bottom - from memory the bottom stud is offset so I slotted the holes in the crossmember width ways - and by rotating the mounts I can probably move the engine forwards or backwards over a 30-40mm range which helped for fine tuning the position.
    Can get a measurement on height for you later on - I don't have the stock mount measurements on me any more as its been a few years since the conversion.
  10. #190
    Glenn
    North Ringwood
    andy im using 2 s engine mounts and brackets and they bolt up ok to the altezza motor and i havnt had any problems these have been in the car since 99
  1. What did you do on your ae/ke today thread
    By dove grey 64 in forum Melbourne & Vic Events and Discussion
    Last Post: 19th December 2013, 01:49 PM
  2. 3SGE Beams
    By Jacobxxx in forum Ebay Items - My Stuff
    Last Post: 29th October 2012, 12:03 PM
  3. 3sge Beams Coilpack
    By HiroshiFumi in forum Cars or Parts Wanted
    Last Post: 14th January 2012, 06:33 PM
  4. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  5. beams 3SGE questions
    Last Post: 22nd May 2009, 07:50 PM
