I actually only measured the distance from the crack pulley to the chassis rail.
But I also made the holes stretched for any small corrections later.
Here is a link to the build:
Greets,
[QUOTE=Aram;915447]Not that I can tell no.
But you can always adjust 5mm imo, people usually change the suspension anyway when undertaking such a big project.
I used the BEAMS engine mounts, made 5mm plates on the subframe, I also hammered the subframe down a bit in the middle so the engine fits better.
And I tilted the engine like it does in the Altezza, not sure why they tilted it but I figured they had their reasons so I did
Aram, was the LH and RH mount plates on your engine support exactly mirror image, meaning the distance between the centre of the engine support to the Beams engine mount bolts are the same LH and RH?
Cheers,
Vener
Greets,
Im considering what engine to drop to my ae86. I have done some research regarding beams swap to ae86 and i know that it needs fair bit of modification to get it fit. My biggest fear is regarding the beams oil pan and its ground clearance. How low beams oil pan is versus stock 4age oil pan if the beams is sitting as high as it can with still original hood without any holes. I would start swapping beams right away but id like to keep my corolla as low as its now without always risking oil pan
Sorry for bad english, im from Finland
Just get a Volvo 360 isn't that what all Finnish people drift? Hahah!
... but seriously Finland looks like an awesome country!
Do you have the seisou?
I know only few 360 projects in here, i think thats more uk thing Finnish ppl drift soarers, 200sx and skylines i think :p
What you mean by seisou?
Yeah I was just making generalisations about European drifting! haha!
I don't know I heard Mika Hakkinen say something about it! I thought you'd know.
What I meant was sisu.
Ah, Sisu stupid me I dont know if i have sisu, im kinda lazy lol
If you haven't already read this do
1.5-2" lower. Depending on your mounting solutions. Maybe only 1-1.25" if you don't mind really really working for it.
Quick question, when using the stock ECU and loom with the RS200 3SGE is the original loom long enough to run it into the car rather than having the ECU and box inside the engine bay? Noticed on the link to the 6 speed one they appeared to run the loom into the firewall
