5s put you out of the under 2l class if you are interested in racing
oh I see, I didn't know that. Hopefully James here hasn't gone out and bought himself a block already
I saw back a while ago that a guy with a RA23 fitted the J160 with no modification to the tunnel besides the gear stick. Assuming it fitted his Celica, would you think the J160 would fit in a RA65/SA63 tunnel with no modifications?
im mid way through getting my beams + 6 speed into my AE71 wagon
cars getting 4 link with R31 diff also.
couple questions if thats cool. i wanna run ITBs my best option is looking to be get Black top ITBs and an adapter. can anyone recommend the best ecu to use, im happy to do something with a full loom that wires into factory plugs ect, so iv been looking at the adaptronic e420d.
to go with that, which tuning shops in vic would be best to tune a 3sge, as i dont trust my self with any of that.
also where can i get a speed reading from for a speedo?
also, can anyone recommend a clutch/flywheel to use with the gearbox if the dual mass isnt a good idea for drifting?
Thanks, Adam.
try chasers in kensington and use a supra box speedo drive and your cable will connect up and i sell the trd copy adapters with cable bracket etc
I didn't thankfully, yeah my intent is to go racing with the car eventually, but just a few club days/regularity for now.
Just more brain picking, what Australian delivered cars have the same parts? Rather than forking out and buying 'listed' RS200 stuff. Eg; IS200 clutch, 97 SW20 Timing Belts
kaizen garage do a plug n play loom to suit the adaptronic.
that's good, it would really bother me if someone wasted their time and money because of my misinformation. Now for your question I don't know how clutch compatibility is however the timing belt bits are all different. That said though I can supply you every part on the engine genuine. I have on the shelf every cam drive part, water pumps, seals, exhaust gaskets and oil pump. The timing belt kit has the belt, hydaulic tensioner with it's own pulley and the two extra pulleys, this is $230 or 340 with a complete water pump and housing.
Alright so car is almost ready to go but now iv noticed that the BEAMS is a returnless fuel system.
Now, am I right to run one fuel line with an EFI pump to the stock input on the rail or am I going to have issues?
If its all good what PSI, 60?
Disregard this now, decided I wasn't going to be happy without a return
