Page 6 of 40 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 51 to 60 of 400
Thread: Universal 3sge (inc Beams) into AE/KE thread
  1. #51
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Andy San
    Quote Originally Posted by Anthony View Post
    One of the top bell housing to block 12mm bolt holes is out by about 15mm. The other 3 and both dowels are fine, just that one hole. Worth it to get the clutch and starter on the drivers side.
    Definately. The 2s one wouldn't work with a beams anyway as the starter would be right in the way of the oil drain.
  • #52
    Endeavour Hills
    Anthony
    Quote Originally Posted by driftke70 View Post
    indeed
    you ever end up doing those modified 20v starters?
    I found 2 20V starters which I have here. Just no bell housings around to set the job up with. Sold them all. Easy enough job though, if anyone needs a bell housing modified with a modded starter to go with it I could do that.
  • #53
    Endeavour Hills
    Celica RA45
    so andy when you set this up for ipra it might pay you to get a racing clutch ,like a 5inch dia . i seem to be braking straps all of the time
    and if you saw what i put up you are not aloud to cut the tunnel at all only love taps same for the fire wall
  • #54
    Endeavour Hills
    hey can someone post a pic of how the 3S beams sump fits in relation to the steering rack and crossmember?
  • #55
    Endeavour Hills
    now with this has all been coppied to here this is open for further discussion.
    Here is a new question for you guys, whats the big deal about the oil return in the way? I mean why not make a new one that goes around the starter? Without me ever seeing one I don't know what the deal is
  • #56
    with the way my mounts are going to sit i have to cut some of the sump webbing just near the bellhousing. this is to clear the steering rack brackets
    sorry about the crappy red lines but you get the idea
    this is with the beams version. the motor will sit under the seam on the firewall. so this is if you want it as low and far back as possable. you will most probley (6sp defenently) need a new tunnel and bash plate if you go to this extreme
    who knows alittle more about the quads convertion for beams? throttle setup most specificly
  • #57
    Glenn
    North Ringwood
    you need to run black top throttles as a minimum or larger such as up to 50mm
  • #58
    Veteran AJPS's Avatar
    Lonsdale
    So glen, im going to run cams in my motor 268s, will i need to go bigger than black top quads? What do you suggest?
  • #59
    Glenn
    North Ringwood
    so you are going to use the toda cams, that can use the std ecu, 268 on inlet and 264 on exhaust .
    std cam is 264 on inlet so you are not going up much so the black tops will be fine
    its when you increase lift .like 14mm and more duration like 320 advertised and 266 at 50 would be better off with bigger throttles and more comp etc
  • #60
    Lonsdale
    I was going to use thinner headgasket etc,
    what options are there for bigger quads? As in that have adapters available
    Ill take it to pm
  • Page 6 of 40 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
    1. What did you do on your ae/ke today thread
      By dove grey 64 in forum Melbourne & Vic Events and Discussion
      Last Post: 19th December 2013, 01:49 PM
    2. 3SGE Beams
      By Jacobxxx in forum Ebay Items - My Stuff
      Last Post: 29th October 2012, 12:03 PM
    3. 3sge Beams Coilpack
      By HiroshiFumi in forum Cars or Parts Wanted
      Last Post: 14th January 2012, 06:33 PM
    4. Replies: 12
      Last Post: 29th November 2010, 09:00 AM
    5. beams 3SGE questions
      Last Post: 22nd May 2009, 07:50 PM
