Page 7 of 40 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 61 to 70 of 400
Thread: Universal 3sge (inc Beams) into AE/KE thread
  1. #61
    Glenn
    North Ringwood
    my inlets will suit black top or my 48/50 mm throttles ,and using the thinner head gasket is not worth the 250 that it costs when it only moves the comp from 11.5 to 1 to 11.9 to 1
  • #62
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    If anyone has dry sumped one of these what brand pump did you use and where abouts did you locate it?
    Andy
  • #63
    Veteran AJPS's Avatar
    Lonsdale
    What about a data base of
    Things like
    Oil filters
    Spark plugs
    Head gaskets etc
    General consumables.
  • #64
    Moderator Sam-Q's Avatar
    Endeavour Hills
    can someone tell me if any bellhousing off a Y engine will be compatiable with an S engine after the pre mentioned mods?
  • #65
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Yes.
    I haven't looked into what other transmissions the Y-series may have come with, so make sure it mates to a G5x trans (same pattern as W55-59) if your going to try and RWD a 3S.
    Andrew
  • #66
    Endeavour Hills
    thanks, might you happen to know which vehicles came with that gearbox in australia? which versions are there exactly so I may look it up? G5?
  • #67
    Dec 2009
    Andrew
    California
    Nothern
    USA
    G52 for example (replace X with whatever 'version' of the g5x series trans it is).
    Toyota 'Van's' would have them, liteace/townace. Some Crowns. I'd try and cross reference off this list: http://en.wikipedia.org/wiki/Toyota_Y_engine as I'm not exactly sure what you guys would have gotten.
    Andrew
  • #68
    Endeavour Hills
    yeah I saw that list but I didn't know which ones where the same as the W box, ok time to go hunting at the self serve wrecker.
    Oh and it's for a 5S, same thing I know
  • #69
    Andy
    Adelaide Hills
    sam i have a g52 box at home, thought it was a w57 till i looked closely at it the other day. (4 bolt shifter) Mine is from a 2wd hilux with a 22r motor. they have crappy ratios for any sort of sporty driving though.
    Andy
  • #70
    Anthony
    Quote Originally Posted by Sam-Q View Post
    Yes it will
  • Page 7 of 40 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
    1. What did you do on your ae/ke today thread
      By dove grey 64 in forum Melbourne & Vic Events and Discussion
      Last Post: 19th December 2013, 01:49 PM
    2. 3SGE Beams
      By Jacobxxx in forum Ebay Items - My Stuff
      Last Post: 29th October 2012, 12:03 PM
    3. 3sge Beams Coilpack
      By HiroshiFumi in forum Cars or Parts Wanted
      Last Post: 14th January 2012, 06:33 PM
    4. Replies: 12
      Last Post: 29th November 2010, 09:00 AM
    5. beams 3SGE questions
      Last Post: 22nd May 2009, 07:50 PM
