try a noise filter, talk to someone in Autobahn about one
You know the noise, as i accel the noise chances pitch. And its getting on my nerve. I did just install a new cd player but the noise wasnt there for the first 2 days, and its appeared out of no where. I have double/triple checked all wires and nothing seems wrong.
Engine 20v with haltech loom, rwd 16v alternator.
I have also noticed a humming sound that comes and goes(especially at low idle, stupid 4puk clutch, hard to drive with) from eng/bay. I believe its the alternator area. Would you say its normal too humm when rpm drops
Any ideas help appreciated.
check that the speaker wires arnt earthing on the body
~KEEP DRIFTING FUN~
oh also don't run your speaker wires parallel to your power cables
its usually a power cable run to close to a speaker cable - the tone of the buzz changes with the frequency of the voltage being pumped around the car...if that makes sence.
make sure u have a clean earth aswell
yer bad earth might be your problem dont use washers under the earth pin from the stereo and make shore its clean wire brush it along with the main earth if possible
i had this after i put a sub in my car with the wire that sum1 else put in ...but the rca and power wire was run all on the same side of the car and that give you a buzz . move rca to other side of car ...or speaker wires
2 in the pink 1 in the stink
bad earth
or rcas run near power cable
or blown output in deck.
are you running an amp.
doesnt matter about power cable running near speaker wires. only the signal wire going to amp can make it buzz.
got the same thing in my car, guys at autobarn couldnt figure it out they guessed was antenna replaced it with one in the car still got it, checked wiring while they were doing it still no clue so i kinda just gave up on it, but i get it as u accel the frequency is worse and when u sit in one spot its fine.
All the listed things have been done, all i dig was change head units.
I couldnt here the noise today.
Frikking weird shit..
