Results 1 to 10 of 17
Thread: coilovers, big brakes, swaybars, roll cage
    Brad
    Central coast
    Default coilovers, big brakes, swaybars, roll cage
    For sale.
    ae86 coilovers: ae86 strut, 8kg spring, helper spring, KYB AGX adjustable shock. basicly new. done one track day. $700 (come with s13 camber tops)
    4 pot brake setup: volvo calipers, puegot rotors, custom brackets on ae86 hubs. great combo. pull up great! bolt on. come with ae86 hubs, new wheel bearings all brackets ect. $550
    or take coilovers and brakes for $1100. bolt in.
    whiteline rear swaybar: not to old, non adjustable $80
    whiteline adjustable front swaybar: painted grey, one of the threads is a bit stripped, easy fix was still using it. $70
    bond half cage: bolt in 4 point. cams approved. will throw in harness bar. $400
    Senior Member Medwin_3sGTE_AE86's Avatar
    Bendyaumum
    Southern
    Is it just me, or is the nuts/rings on the top coilover (first pic) very, very twisted?! I'd be interested if it wasnt....
    User fantapants's Avatar
    Pat
    i think its something funky that hapens with the pics man... cos i said the same thing about josh's coilover setup... the thread is on an angle, but in real life it is plumb as ?:
    sorry for the offtopic... good luck chickens
    06/07/2011
    todd
    pm'd re: swaybars
    Brad
    Central coast
    swaybars are sold pending payment.
    i am awsome at putting threads in the right section.
    Reeece
    Casula
    ill take the rear sway bar if it fulls thru .. I could send money asap if available
    Josh
    Mid North Coast
    hey mate i will take the cage,were do u live? would it be much to frieght? pm me with your mob number!!!!!!
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Moved to the correct section for you.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    pm sent...............................
    BENT MECHANIX - Garage 20:
    c
    Should the swaybars sale fall through i can put the cash in your bank tomorrow
  1. Replies: 27
    Last Post: 12th March 2012, 12:54 AM
  2. 8kg coilovers + big brakes
    By 20v ae71 in forum Car Parts For Sale
    Last Post: 21st July 2010, 12:19 PM
  3. Replies: 1
    Last Post: 5th June 2010, 07:07 PM
  4. AE86 Coilovers, Suspension, JDM Brakes, Swaybars, etc.
    By psychofox in forum Car Parts For Sale
    Last Post: 22nd August 2007, 02:39 PM
