Is it just me, or is the nuts/rings on the top coilover (first pic) very, very twisted?! I'd be interested if it wasnt....
For sale.
ae86 coilovers: ae86 strut, 8kg spring, helper spring, KYB AGX adjustable shock. basicly new. done one track day. $700 (come with s13 camber tops)
4 pot brake setup: volvo calipers, puegot rotors, custom brackets on ae86 hubs. great combo. pull up great! bolt on. come with ae86 hubs, new wheel bearings all brackets ect. $550
or take coilovers and brakes for $1100. bolt in.
whiteline rear swaybar: not to old, non adjustable $80
whiteline adjustable front swaybar: painted grey, one of the threads is a bit stripped, easy fix was still using it. $70
bond half cage: bolt in 4 point. cams approved. will throw in harness bar. $400
i think its something funky that hapens with the pics man... cos i said the same thing about josh's coilover setup... the thread is on an angle, but in real life it is plumb as ?:
sorry for the offtopic... good luck chickens
06/07/2011
pm'd re: swaybars
swaybars are sold pending payment.
i am awsome at putting threads in the right section.
ill take the rear sway bar if it fulls thru .. I could send money asap if available
hey mate i will take the cage,were do u live? would it be much to frieght? pm me with your mob number!!!!!!
Moved to the correct section for you.
pm sent...............................
BENT MECHANIX - Garage 20:
Should the swaybars sale fall through i can put the cash in your bank tomorrow
