are they adjustable cam gears? why did you take the cams out after only 2500kms of use?
For sale: Pair of TODA 288 deg 8.5mm lift 16V cams.
Item Description: 288 degrees duration, 8.5mm lift cams, biggest lift cams you can buy before the inner shim kit is needed
Item Condition: Cams look mint, no scoring etc, only done around 2500 kms or so.
Asking Price: Cams - $800. Gears- $400. Belt- $100 if you buy cams and gears get the belt for free.
contact on 0434460765 (cal) or pm
If they are Touge Boys old ones, they are nearly brand new HKS adjustable cam gears, toda cams and toda cam belt.
Cam gears had never even been adjusted when they were taken out of his car.
i believe they are
