Results 1 to 4 of 4
Thread: rear drum pad removal
    c
    Default rear drum pad removal
    So iv never changed rear drum pads only had disk brakes. How do i remove and replace?
    Thanks in Advance
    Veteran driftke70's Avatar
    Ryan
    Buderim
    side cutters to take springs off, dont cut them, side cutters just hold em better, then take the pins out that hold the shoes in, they have a little clip that you have to push in and turn. Then take pads off, put new ones on, making sure they are the right way round, put pins in, line up the adjuster, put springs on, put disc on, and keep adjusting till its pretty hard to put the drum back on, so it only just touches when you spin it round. i like to get a garden hose and gently rinse all the old shit out of there, good to get like a dust pan brush and gently brush all the shit out, i normally do wheel cyl while im at it.
    wheelfriends.wordpress.com
    Senior Member Dylan's Avatar
    Dylan
    ^ +1 on doing wheel cylinders aswell
    Ryan
    Buderim
    yeah to check your wheel cyl just squeeze the little round rubber on the side of it so it makes a small hole, and if brake fluid leaks out, its fucked.
  1. TA22 rear - drum to drum QLD
    By frosty in forum Cars or Parts Wanted
    Last Post: 12th November 2012, 05:14 PM
  2. Sprinter Rear Disc Anti Rattle Shims/Pad Guides
    By archie1 in forum Technical - Questions
    Last Post: 8th January 2011, 12:30 PM
  3. Rear drum brake removal?
    By Ade_Mc in forum Technical - Questions
    Last Post: 28th December 2008, 07:03 AM
  4. t series drum to drum rear end
    By Grantobius in forum Cars or Parts Wanted
    Last Post: 24th January 2008, 07:20 PM
  5. complete Ra40 drum to drum rear
    By orido in forum Car Parts For Sale
    Last Post: 4th January 2008, 12:30 PM
