assuming that is negative 1.5 to 2 deg that should easily be fine to start with.
If that isn't enough read the lower control arm thread in the tech articles forum...
hey all im new to here. well. new to toyota. im 16. on my L's. and about to buy a nice e7 soon.
was just wondering. the e7 im buying does have the adjustable strut tops but. its on full camber and pulling only about 1.5 - 2 degrees. if that. wtf?
how other then strut tops can you get camber?
p.s sorry for noob question. youll all probably be getting alot of them from me
cheers.
Thats all camber tops will give you, 10mm longer lower control arms will give you another 1 degree or so.
-2 is enough for street use will still kill ur tyres fairly quick, so if i were you and guessing you dont have much cash just leave it at -2 at max cause you probably dont have money to fork out for new fronts all the time
okay cheers everyone. been looking at mesurments and might go with sigmas. maybe..
XT130's are fine bro, you shouldn't need any more than 3deg...
Track increase looks/feels wack aswel with sickmas
yeah but might need alittle more then just strut tops to fit in the wheels.
whats a perfect fitment? like what are you guys running?
umm what specs are the wheels you're planning on running?
most people just run xt130's
hoping 13 by 8 on front and maybe 9-10 on back. i have all kinds of spacers laying around to so i wont be short of fitment. just wondering what i could fit with a 35mm spacer on front maybe?
