Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 41 to 50 of 85
Thread: not another RT142............
  1. #41
    Seth
    motospecs in QLD do steering rack seal kits
  2. #42
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    couldnt be a fucked tie rod end?
  3. #43
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    ive bend rack ends before check those as they are prety weak,
    the noise your describing tho sound like what i had, i found the balljoint nut lose on the steering arm so maybe check for that?
  4. #44
    Senior Member macca1590's Avatar
    Central Qld
    ke70 rack is a fair big shorter as expected, but you just never know aey
    pulled other rack apart today, the rack has movement parallel to the pinion at the input shaft end(dose not have a bush at this end), but when you adjust the thingo until there is no movement it is almost impossible to turn the input shaft and when you do its very notchy, as if the teeth are bottoming out, and when you pull the pinion out there is definitely some wear but i wouldn't have thought it be enough to make it this bad. and the noise it was making is the same as the one thats in the car now so they must just be plain old worn out........................
  5. #45
    Central Qld
    bored on weekends leads too....................
    thats just primer atm and yes i did splash out a bit on the spray gun hahahaha
  6. #46
    Member DRIFTRT142's Avatar
    Jan 2011
    Mark
    Seaton
    I sell those spray guns for a living!! Don't hate me haha looking good man, love the wheel choice
  7. #47
    Central Qld
    hahaha yeah i didnt think it was too bad, but i have never used one before so i dont know whats good or whats bad, it was all a big learning cruve, but in the end i dont think it turned out to bad, would look heaps better if i could get off my ass and wash the rest of the car thoe, and ill have to give that section a nice polish to get it shining
    so that only took me 2 and a half days so a whole car would take.............. 4 weeks? haha
  8. #48
    Central Qld
    lucky i have a mate who has a old 22r from a hilux with a spun big end that i was able to steel a valve and valve guide out of...... just a tad dodgey haha
    did this while installing new cam, also have changed timing chain, sprockets, guides, tensioner, water pump, timing cover, valve springs, wideband o2 sensor and just got extractors and full exhaust done the other day.
    i had the head sitting on the block and while putting the rocker gear on and using the bolts to pull it into place the rocker mustn't have been sitting on the valve properly and bent it and i broke the guide tring to bash the valve out. lessons i wont soon forget.
    also the other week installed ra40 LCA's which is same as xt130 im lead to believe, new bushes and ball joints, ra65 power steering arms and RCA's just need a proper alinement's and it shall be all sweet. but now my rims stick to far out of the stock grards, soo lucky i have some new ones on the way................ pics soon
  9. #49
    Jan 2011
    Mark
    Seaton
    cant WAIT to see pics. shoulda got one of Torker or Crawler cams on Ebay for these
  10. #50
    Central Qld
    its from the same company, cant find anymore on there but this is the specs that i copied- SPECS: 270° advertised duration, .430" gross valve lift
  1. rt142 rona!
    By RRX-007 in forum Other Toyotas
    Last Post: 14th January 2015, 12:46 AM
  2. Replies: 5
    Last Post: 18th January 2012, 03:47 PM
  3. rt142
    By wntdae86 in forum Melbourne & Vic Events and Discussion
    Last Post: 4th September 2010, 07:08 PM
