Lots of Toyota throttle cables will fit at the pedal end. The main difference in them is length. I have been told, for a AE86 and 20valve, a KE70 throttle cable works well.
hey guys my throttle cable has been stretched to the maximum im just wanting to know if toyota still sell them genuine and i have a ae101 20valve so do i get a ae101 throttle cable or just a sprinter model one???
do both fit??
thanks for the help in advance
buddyparts sells jdm ones for cheap as shit,
dunno if they'll fit a 20v conversion but
ive jsut put a 16V in my ke70 and i can tell you the ke70 one is too long.
you have to wrap it around the brake booster thus it makes the pedal real hard to push down.
i am yet to find a shorter one, but all cables are generally the same, its just a wire with a cylinder looking thing attached to the end.
you can always go and get a ke70/ae86 on shortened, or it prolly isnt that hard to shorten, just re crimp the threaded end on. and re crimp the cylinder looking thing...
i intend on just goin to the wreckers and finding a different one that looks to be a better length, just measure the length you need from the firewall and go searching!
EP91 Starlet is the go for a standard 16v 4AGE.
Usually though a KE70 cable is suited to 20v conversion because the cable usually needs to be looped around the front of the quads then back to the throttle lever thingo.
KE70 one is definitely too long for a 16v though.
ke70 one worked for me
ok sweet has ill go a ke70 one then
does anyone know if toyota still make these new or knows a place that does???
There are cheap knock-off KE70 throttle cables new on e-bay. Not Toyota, but should work. I have one here I ordered just to look at it.
get it repaired here.... have had these guys modify heaps of throttle cables for me....lengthen....shorten....whatever you want...cheap too!!
brad
