Results 1 to 10 of 15
Thread: drums are stuck
    Senior Member shinny's Avatar
    Liam
    Default drums are stuck
    hey all,
    trying to remove the drums on my diff (T-18 diff) and they won't come off,
    i've tried screwing 2 bolts in the face of the drums to remove them but they are too tight and the threads are getting stripped,
    also tried prying them off with no luck, i think the drums are seriously lipped,
    can anyone throw some more ideas up???
    todd
    Large hammer.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    make sure you hand brake is completely slack, then just give it one good solid wack on the face with a hammer towards the middle imbetween the studs, gets em off every time.
    wheelfriends.wordpress.com
    Mt Macedon
    Often when I had slightly lipped drums and they got over tightened I had a hell of a time getting them off. Eventually I resorted to levering them off against the backing plate. Stuffs the backing plate, but everything still works.
    Not recommended if you care too much about how they look.
    Peter
    Kellyville
    wind back the brake shoe adjuster all the way - will get you under the lip
    Calvin
    Kilsyth
    yeh wind back adjuster is good. prolly have to lever them expect to break stuff/bend backing plates. i fkn hate working on drums with a big lip on them. just keep levering and they'll eventually come off.
    Calvin
    Rob
    Moorabbin
    Lol, don't use brute force till they come off... just wind back the adjuster through the windown on the backing plate, it can be a little fiddly but better than bending stuff
    Mt Macedon
    Can you wind them off through that window? I always assumed that you wouldn't be able to push the rachetting arm off the star shaped part of the adjuster, and so couldn't back it off. Then again I never could be arsed climbing under there and checking too closely.
    Senior Member *E7*'s Avatar
    Dave
    Eastern Melb.
    is your handbrake off?
    have seen it left on before.
    Liam
    Quote Originally Posted by *E7* View Post
    haha yes the handbrake is off
    cheers to everyone for the replies, i'll see how i go
  1. wtb drums off a s or t diff
    By dehney in forum Adelaide & SA Events and Discussion
    Last Post: 13th July 2009, 01:27 PM
  2. T-18 drums
    By Hokey in forum Technical - Questions
    Last Post: 2nd May 2009, 11:04 PM
  3. S and T series drums
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 27th July 2008, 12:05 PM
  4. drums/ interior wanted
    By sik-86 in forum Cars or Parts Wanted
    Last Post: 20th February 2007, 04:44 PM
  5. ae86 rear drums
    By sik-86 in forum Technical - Questions
    Last Post: 13th February 2007, 07:18 PM
