Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 33
Thread: 180kw 4AGTE DRIFTER
    Billy
    Tarragindi
    Default 180kw 4AGTE DRIFTER
    Just some pics from a photoshoot.
    These are the specs
    Engine:4AGE 20 Valve Silver top
    Engine hardware
    Custom oil cooler kit and filter relocation kit, custom oil catch can and modified baffled sump. Nissan trx bluebird radiator with dual thermos, Ground and balanced standard crankshaft, 20 thou over boar with oversized weisco forged pistons 8.5.1, Shot peen and polished 4agze conrods with arp conrod bolts. Arp race bearings throughout, Arp head stud kit, Angular block modification for big end bearings, Aftermarket valve springs, multilayer metal head gasket, s15 t28 turbo with .49 rear housing, 38mm external waste gate and screamer, Custom plenum chamber with 3sgte throttle body,1jz injectors, Adaptronic ecu, ae101 coil packs, Straight through 2.5inch exhaust, Custom surge tank with braided line and bosch 044 fuel pump and fuel cell.
    Drive train
    W55 Celica gearbox, 4 puck ceramic clutch, E series light ace diff locked and converted to disk with s13 disks with 4.3 diff gears. One peace tail shaft.
    Brakes/Suspension
    Front-Custom made front coil overs with 8kg swift springs and kyb agx 4 way adjustable shocks, Ajps front sway bar, T3 camber tops and custom strut brace, Ae86 power steering arms, Sigma lower control arms and t3 RCA’s, Quaife Quick Rack. Jdm vented rotors with braided break lines.
    Rear- Custom made coil over’s using 6kg springs and kyb agx 8 way adjustable shocks and a T3 rose jointed adjustable pan hard rod. Rear Ajps Sway bar and Ajps traction brackets, rose jointed adjustable rear trailing arms, Nolothane bushes throughout car. s13 rear disks.
    Wheels and tyres
    15 by 8 -4 Super lights all round with 195 50 15 nankang ns2s for now.
    Bodywork
    Hand flared guards front and rear, Repaint in Alpha Romeo Silver.
    Interior
    S15 dash fitted with digital sabre gauges and ace well digital dash, Bride recliner for driver and passenger and Trust harnesses, kkr deep dish suede steering wheel, Trust gear knob. Jap spec turbo timer and custom made hydraulic hand brake and line lock kit.
ID:	12256   Click image for larger version.
ID:	12257   Click image for larger version.
ID:	12258   Click image for larger version.
ID:	12259   Click image for larger version.
ID:	12261   Click image for larger version.
ID:	12262   Click image for larger version.
ID:	12266   Click image for larger version.
ID:	12479   Click image for larger version.
    Billy
    Tarragindi
    Here are some vids of it hope you like it.
    ( this is the latest archie run, only second time of driving it turbo soooo slowly getting the hang of it ).
    Mar 2010
    first in ahha that dope man wat setup u running with cooler and we need pics please
    Mar 2010
    sounds sick man
    Ok
    Seamus
    Milton
    awesome dude. you should edit your first post with some specs of your motor/suspension/diff/etc setup looks great
    Davey & Riki-lee
    South Australia
    Seaford SA
    omg that makes me so wet! love a 4agte! more pics!
    Our introduction - Click here
    Mar 2010
    please more pics it 20vturbo but engine pics would be mint
    Member the_van_can's Avatar
    Mar 2010
    Row
    Strathpine
    S13 dash, think iv seen you on ke70.com, your cars nuts, good work.
    Mar 2010
    s15 dude
    Billy
    Tarragindi
    Engine hardware
    Drive train
    Brakes/Suspension
    Wheels and tyres
    Bodywork
    Interior
    S15 dash fitted with digital sabre gauges and ace well digital dash, Bride recliner for driver and passenger and Trust harnesses, Custom alloy rear firewall for fuel lines (In cabin) kkr deep dish suede steering wheel, Trust gear knob. Jap spec turbo timer and custom made hydraulic hand brake and line lock kit.
  1. my daily / drifter
    By bones in forum AE86 Owners Forums
    Last Post: 26th April 2011, 12:09 PM
  2. My Ke70 drifter
    By MickeyH in forum KE70 / AE71 Owners Forums
    Last Post: 20th August 2008, 11:08 PM
  3. Drifter gets munched....
    By WaLLY in forum Toyotas in the Media
    Last Post: 4th June 2007, 03:21 PM
Tags for this Thread
