Results 1 to 5 of 5
Thread: E seies diff ratios
    Default E seies diff ratios
    Hi all i really need to get my hands on a couple of E series diff ratios.
    Im after a 4.1 and a 4.5 and need them before running at Bathurst later in Febuary. any help appreciated
    Veteran slydar's Avatar
    Dimitri
    ill try to dig you some up. pm me some contact details so i can get in touch. depending on where theyre sourced, youre looking at between $150 and $250. sometimes even less but its a bit of a lottery. if those prices sound ok, then i can make a proper effort to try to find you something, but yeah, if you forward me you daytime contact number, i can give you a call and get your go ahead before buying.
    Jonathan
    I know of a 4.1:1, but you have to buy the whole car which is in TAS. (But it's cheap).
  • #4
    Senior Member GOODY's Avatar
    Logan
    I've got a 4.8 diff here but I'm not sure if it's an E series, is there any way to tell by looking at the case etc.?
  • #5
    Slydar i can be contacted on 0414 482320.
    Johnny the whole car is a bit too big for me to deal with but thanks any way.
    Goody Ive got a 4.8 but thanks any way.
    Im just chasing a 4.5 now. thanks for all your help so far.
  • Similar Threads
    1. same dyno different diff ratios
      By Celica RA45 in forum Technical - Questions
      Last Post: 24th January 2012, 05:21 PM
    2. T18 Diff Gear Ratios
      By the_van_can in forum Technical - Questions
      Last Post: 17th January 2011, 10:01 PM
    3. Info on F series diff ratios above 4.3
    4. Diff ratios
      By AE86_4life in forum Technical - Questions
      Last Post: 7th February 2008, 04:04 PM
    5. diff ratios?
      By not for show in forum Technical - Questions
      Last Post: 19th October 2006, 02:06 PM
