Results 1 to 8 of 8
Thread: Blue Slip
    Conrad
    NorthShore
    Default Blue Slip
    Just wondering does anyone know the checklist for getting the blueslip in NSW? im not sure if my car will pass. cheers
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Basically, car must be bog stock.
    No diff leaks
    No torn boots
    No apparent rust
    etc etc
    If you think it might not pass then it probably wont.
    My AE71 was totally flawless on all the important parts (seals, boots, shocks, captive springs etc etc). But they raped me hard on rims (figured I'd try my luck, they are only 14 x 6.5 +15 SSR meshies but still got hammered on them). Said the suspension was too low (not even tucking rims anywhere) and above 100mm. Exhaust too loud (granted I even thought it was). And told me to get my 4AGE engineered (after having told me before the inspection that I didn't need to get it engineered because it was the same capacity)....
    So after all that, I'm just gunna find another place without a pole up there ass change a few things and the car will be on the road. You are allowed to go wherever you want at any time with a blue slip, so if one place fails you, you can just look for a better place.
    What do you think they'll do you for?
    Senior Member 45aken's Avatar
    Marko
    blueslips are pretty tough regardless of where you go these days.
    try your luck i guess, i found that it helps if you keep everything clean and tidy.
    the only requirements on suspension are that the lowest point must clear 100mm, so i dunno what they were on about there.
    Conrad
    NorthShore
    cheers guys.
    i think ill try my luck.
    only worry is the 4age engineered part. hope they wont be as anal as that.
    as for exhaust...im pretty sure my car is under 90db.
    ill see what happens....
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    what if your horn doesnt work , i just dropped my car off completely stock except for 15x6 wheels with new rubber, but the horn doesn't work.. but then again, when i bought my car the horn didn't work and it passed a roady.
    Edit: I forgot to put the spare wheel in O.O
    if your in sydney
    give a PM to Paul sexy16
    he can get you one and get it on the road
    Ade
    SYD, Inner west
    Quote Originally Posted by mini bus View Post
    if your in sydney
    yes it is true!
    picked up some parts off paul, the guy that works next to him does blueslips.
    my exhaust is too loud, passed. top bloke
    Conrad
    NorthShore
    hahaha you serious? what a top bloke!
    well ive booked in on thursday at some workshop near my place, should be fine. but if they're anal ill be sure to pm him. ahha
  1. Blue slip
    By jimhead in forum Sydney & NSW Events and Discussion
    Last Post: 5th August 2009, 07:47 PM
  2. Need Parts for Blue slip
    By Dr ae8666 in forum Cars or Parts Wanted
    Last Post: 10th February 2009, 07:44 PM
  3. blue slip
    By tim.duncan in forum Technical - Questions
    Last Post: 13th June 2006, 07:16 PM
  4. Can i get blue slip??
    By distant00 in forum Technical - Questions
    Last Post: 15th March 2006, 09:25 PM
