Results 1 to 4 of 4
Thread: where to buy a one-piece 4K manifold gasket
    Senior Member greeneyes's Avatar
    Vlad
    Sacred Valley
    Cusco
    Peru
    Default where to buy a one-piece 4K manifold gasket
    I pulled the manifolds off the 4K this morning and found they are leaking between the exhaust ports. (surprise surprise.. piece of shit design!)
    Anyway, the only manifold gasket from ACL is a two-piece one, just like the leaky pair that came off. Repco & Supercheap & Auto-one & Autobarn all seem to stock ACL gaskets now.
    The one-piece ones exist, they come with the full headset for over $100 !
    Does anyone know where I can buy a one-piece gasket by itself?
    Vlad
    Sacred Valley
    Cusco
    Peru
    Solved!! Permaseal EM30 on the way from Melbourne!
    Hope it fits OK!
    Kieran
    Just wondering where you actually got it from and how much they cost
    Vlad
    Sacred Valley
    Cusco
    Peru
    $10 from Mid-Western Spares here in Orange. They had to get it in.
    Changing the oil filter solved the start-up bearing rattle. The filter we bought it with did not have a non-return valve in and emptied itself overnight, leading to 20seconds of bottom end bearing rattle every morning.
    Changing the gasket has 90% cured the chuff in the morning, I can just hear it. Seeing we've only cold-started the car once I'll run if for a day or two and see if its worth popping the gasket off and using some sealer around it. I put it on dry and clean.
  1. Silvertop inlet manifold to head gasket.
    By LittleRedSpirit in forum Cars or Parts Wanted
    Last Post: 2nd February 2010, 11:55 PM
  2. 4k Exhaust Gasket
    By flynnske in forum Technical - Questions
    Last Post: 20th November 2009, 09:07 PM
  3. blacktop manifold gasket/spacer
    By grantobius in forum Cars or Parts Wanted
    Last Post: 8th November 2009, 08:50 PM
  4. replacing inlet manifold gasket
    By squish_m8 in forum Technical - Questions
    Last Post: 1st June 2009, 11:45 AM
  5. Where to buy Metail head gasket for 16v?
    By omy in forum Technical - Questions
    Last Post: 28th June 2006, 07:55 PM
