Results 1 to 10 of 13
Thread: Noisy+ not down shifting into 3rds
    Senior Member tezza88's Avatar
    Terry
    Lansvale
    Default Noisy+ not down shifting into 3rds
    i know this is a common problem but i'd like to know how much it'd cost to fix it
    or if there are any quick fixes like gearbox fluid choices. so far i'm just using manufacturer recommendation from Castrol
    i guess my questions are
    1. whats wrong? why cant i throw back into 3rds and i have to fake a 2nd gear?
    2. quick fix vs replacement?
    3. approx how much and who? (general mech etc?)
    JDM T-50 btw
    Appreciated guys
    Terry
    Mt Macedon
    Sounds like your 3rd gear synchro is stuffed.
    You can pull the box apart and replace it (though I've read only some of the required parts are still available) but in my opinion it'd be cheaper and easier to find a good replacement and throw that in. I can't comment on different oils and the magic they work.
    Or simply live with it and double clutch on 4-3 shifts. It'll become second nature in no time.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    yeah synchro no doubt, it's not unusual for them to go
  • #4
    Veteran blair's Avatar
    Blair
    Sheldon
    Chuck some Auto GBox oil in if you're keen, its alot thicker.
    Helped a tiny bit in mine...
  • #5
    Terry
    Lansvale
    hen, its already become 2nd nature shifting like that but i thought with end of financial year i want to see if i can do something about it
    well then on to my next set of questions
    1. when replacing a gearset, would that solve the problem or are synchros a separate issue? (heard some sets are designed for shorter ratios etc)
    2. are there sets out there that are cheaper but just as awesome as TRD
    3. and finally, the aim in the next 5 years or so is to hit the 200hp mark NA, so would it hold up? or should i jst go W58? (id rather something light i.e keeping T50)
    sorry for all the noob questiions guys
  • #6
    Veteran Skylar's Avatar
    Ken
    Buy a rebuild kit. I think I have one here to sell. Has all the synchros, bearings, seals but not the selector-hub-thingies.
    Gearset is only the gears. You normally put new synchros and other stuff with a new gearset unless it's dog engagement where no synchros are used.
  • #7
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    i beleive dex 3,Type-J, Ford 4 speed, oils (auto oils) are a lot thinner then normal (75-85, 80-90, 85-140) gear oils
  • #8
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    double clutching+rev matching is the way and never look back. itll make you a better driver and you wont need synchros
  • #9
    Terry
    Lansvale
    rev matching doesnt stick either. how much would a rebuild kit set me back? and any links to a race gearset would be awesome (TRD is overpriced). il save up for all that and do it altogether.
    i hear there are some jap brands out there which are just as good (gearsets) without the extreme price of TRD
  • #10
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by blair View Post
    No it isn't.
    Yes they are, and can help a box that has half way had the dick as both you and blair said. Use Dexron 3. Standard fare Automatic Transmission Fluid for a falcadore.
    Quote Originally Posted by riojin View Post
    Do this.
    Quote Originally Posted by tezza88 View Post
    ALOT. FAR more than trying to find another box.
    Hell, you could almost convert to a W5x for the price of an aftermarket gearset and rebuild. Maybe even an AZ-6 conversion done on the cheap. Maybe not. HA. Refer to my edit below.
    1 - Seperate Issue. But if you gave it to a gearbox joint they'd certainly tell you how fucked they are and how badly they need replacing and how long your wallet is going to have to spend in hospital recovering from the ordeal.
    2 - Quaife? http://www.quaife.co.uk/catalogue/products/qke4e
    Only 3000 pounds, dog engagement, straight cut. You get a dog-leg first, too!
    3 - If you're staying NA and going for the 200HP mark and you're not racing in IPRA go for a 6spd AZ6 conversion. If you can't afford it then just do the W5x.
  • Page 1 of 2 1 2 LastLast
    1. ECUTEK - Launch Control and NO Lift Shifting for the BRZ / GT86
      By Matt in forum GT86 / BRZ Technical Questions / Modifications
      Last Post: 27th August 2012, 07:48 PM
    2. noisy T series
      By w84me in forum Technical - Questions
      Last Post: 12th July 2008, 09:54 PM
    3. NOISY DIFF, NEED HELP
      By dr1ft-pig in forum Technical - Questions
      Last Post: 30th June 2008, 02:37 PM
    4. Noisy box
      By hilltop_hoodlum in forum Technical - Questions
      Last Post: 23rd March 2007, 01:28 AM
    5. Fixing geabox bushes, for smooth shifting ??
      By Dongaz in forum Technical - Questions
      Last Post: 6th August 2006, 09:53 AM
