location please?
Sold my motor that so I won't be able to use all my 4ag to W58 parts, so I'll be selling most of whats necessary for the swap.
Full details on the swap here: .
200mm Lightweight Chromoly Flywheel (3.7kg IIRC - resurfaced less than 2.5k mi ago. Was $300+)
Almost new 200mm Illegal Garage Clutch (W58 splined - less than 2.5k mi)
ARP crank bolts
And the parts I made/designed to fit it to an AE86:
Custom adapter plate (including hardware)
Custom pilot spacer w/bearing (EDIT: just installed brand new KOYO pilot bearing)
Modified 4a-ge GT-S bellhousing (includes clutch fork/clips/boot & centering tool)
Modified throwout bearing retainer w/bearing (less than 2.5k mi)
Modified trans mount bracket & rubber mount (mount not pictured)
Modified front half of driveline
Basically, add your own W55-59 trans & shifter. Bolt it up and go.
$1100 USD for it all. OR, if your not interested in the flywheel I'll seperate that and could do $900 USD.
Approx. Box Dimensions 24" L x 14" W x 10" H. Shipping Weight for Quotes, approx. 55 lbs.
Located near Sacramento, CA
Andrew
location please?
Whoops, sorry. Meant to put it in the post. I'm in the USA, California.
Andrew
Got my hopes up then smashed em..
ahha, same here.
Ouch, yeah. I just looked up shipping costs and it's gonna at least be $330-350. Unless USPS postal has parcel post to Australia, but they won't quote that online & it has no tracking (although usually significantly cheaper).
Sorry to ruin your hopes and dreams.
Andrew
Hmm. Dunno how much W5x's go for there. But a quick check with google looks like shipped would be around $1600 AUD.
Andrew
Bump.
BTW. I just realized. The bellhousing is the "JDM" 4a to T50 bellhousing which puts the clutch fork/slave on the right/drivers side of the car away from the exhaust. Better for you turbo guys
Andrew
club4ag.com
