Results 1 to 5 of 5
Thread: weld on coilover sleeves.
    Senior Member 70wagon's Avatar
    Jarrad
    Barossa
    Default weld on coilover sleeves.
    hey all
    ive had a bit of a look through the forum but cant realy find any thing about the weld on coilover sleeves i will be using series one t18 struts the main thing i need to no is how much should i be cutting off my strut and what shock to use? is the kyb agx st185 the way to go for the shock? i will be running my car pretty low at all times. so i may noty need an adjustible shock what would be a good shorter stroke shock?
    any help appreciated.
    Veteran shift_rook's Avatar
    SE Burbs
    i'll link you to the thread, i odn't know exactly
    http://www.ae86drivingclub.com.au/fo...read.php?t=820
    Jarrad
    Barossa
    thats handy. thanks mate
    Veteran slydar's Avatar
    Dimitri
    you want an adjustable shock, so that it is stiff enough to control your springs.
    st185 is the shortest insert you can get now, except for trd and tokico. but those are over $500 a pair now.
    unfortunately, there is no shock that is cheaper than an st185 agx, that is stiff enough to control the springs most of us run.
    long story short, get st185 kyb agx. cut the strut right down to suit the insert, done.
    my car runs those, and i can get the cross member right down to about 100mm off the ground.
    this puts the rails at about 70mm. well below legal and quite slammed, an 86 with a kit, will be near on undriveable on the street. lowering beyond this point, it becomes very very hard to keep decent suspension geometry with off the shelf parts anyway.
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    st185 agx is what ive been recomended by alot of ppl (slydar/dimitri) being one of them
    adjustable is a must with stiff springs as the springs are pointless without the shox to go with them.
    MY JZX83 (clicky)
  1. Replies: 4
    Last Post: 4th February 2015, 11:08 PM
  2. What size springs and sleeves for coilover conversion on ae86?
    By Grant #2 in forum Technical - Questions
    Last Post: 25th October 2011, 07:37 PM
  3. Weld on coilover strut questions
    By dogan in forum Technical - Questions
    Last Post: 18th March 2011, 07:02 PM
  4. T3 Weld on Coilover Kit Thoughts?
    By Plelz in forum Technical - Questions
    Last Post: 4th September 2010, 05:46 PM
  5. T3 Weld On Coilover kit With 8Kg Springs
    By Rip it in forum Car Parts For Sale
    Last Post: 9th July 2009, 04:01 PM
