Results 1 to 10 of 12
Thread: All types and specs of 4age engines.
    Default All types and specs of 4age engines.
    Hey guys,
    A while back i remember seing a page with all the different types of 4ages and the specifications of each one.
    Does any one have the link or other links?
    Senior Member ae86=fun's Avatar
    Tobias
    Battery Point
    hope this helps
    Jonathan
    You only have to know these 6 types of 4A-GE. The rest is getting down to very small details you don't need to know anyway.
    -first 16v 4A-GE. "bigport" "T-VIS" Came in AE86, AW11, AE82, JDM AE92 etc.
    - 4A-GZE superchanged "bigport". Came in AW11, early AE92 Levin/Trueno
    -second 16v 4A-GE "smallport" "100kw". Came in AE92.
    - 4A-GZE supercharged "smallport". Has coilpacks. Came in late AE92 and AE101 Levin/Trueno.
    - 4A-GE 20valve. "Silvertop" Came in AE101 Levin/Trueno
    - 4A-GE 20valve. "blacktop" Came in AE111 Levin/Trueno
    That's all you need to know. For power, that is going to depend more on what kid has owned it and whos dyno it was.
    Veteran Nikkojoe's Avatar
    Tom
    Also, coilpacks came out on the early ae92 GZE (afm bigport) as they ran the first CAS setup.
    though wasnt there a site that had pics on every single one?
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I think its also important to mention the second gen bigport which uses the later bottom end with the larger crank whilst still obviously using the bigport head.
    Senior Member Moebius's Avatar
    Christian
    Probably thinking of this one -
    thats the link i was looking for, i always loose it.
    is the 103kw a jap engine?
    Jonathan
    The 103kw engine pictured there is often known as the "100kw". It came in all of the Australian assembled AE93 Corolla SX's. America got the AE92 coupe with that engine. It also came in many late model AE92s in Japan that had the 4A-GE. Maybe on Japans high octane fuel (which Australia didn't have at the time) it made 103kw. I don't expect the engine itself would have been any different.
    Mason
    Salisbury East
    Hey mate there wasn't much difference between Australia & jap, except
    Jap one had 10.3:1 comp ratio. Our Ausy one had about 9.3:1 comp ratio.
    Hopefully that helps.
  1. 4age big port torque specs
    By DearmanKE in forum Technical - Questions
    Last Post: 22nd December 2011, 11:57 AM
  2. 4age engines [melb]
    By hitoriko in forum Car Parts For Sale
    Last Post: 8th January 2010, 12:41 PM
  3. Shed clear out, 4AGE engines,
    By Raceflo in forum Car Parts For Sale
    Last Post: 27th March 2007, 07:16 PM
