Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Flipping Leafs???
    Senior Member Ksevn-T's Avatar
    Default Flipping Leafs???
    hello all!
    Getting rid of my ke70 sedan for a wagon. Wanting to know how i can make the rear end suspension hard as a rock (setup for drift - Track and serious street). It will be running sierras but am unsure what to do about springs. I heard you can flip the springs to get a nice height (Details?) or add lowering blocks and 4 Links to make it rigid?
    Any info would be great from all you wagon sliders out there!
    Thanks,
    Alex
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    get rear coilovers.
    FTP.
    Well yeh, If i had that cash lying around.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    basically flip the whole leaf pack around, it mounts exactly the same on the body side but the diff has to move up about 2 inches to mount again
    wheelfriends.wordpress.com
    Junior Member Mooa42's Avatar
    FirstName
    Vic
    You can flip the main leaf but the best way is to get the ends re rolled, or the arc of the spring inverted so that the spring still works on the same arc as original but the car sits lower. This helps to ensure that the shackles still operate correctly. Either of these options mean you will need to get it done at a spring works and that your main leaf will go over the top of the shakle bush instead of below it.
    If you go with coil overs be sure to reinforce the upper mounting points because they won't be designed to take the full weight of the vehicle and your shocks will end up breaking through the body work.
    I also wouldn't be too concerned with making it too stiff in the rear, soft can help transfer weight over the rears, a good set of shocks should be all you need.
    Senior Member keto's Avatar
    i believe adding a leaf can make it stiffer, it will also make it higher, so get them reset afterwards.
    i have seen helper springs, which is a thick leaf that you can put in, i think there made for utility vehicles but i heard of someone putting them in a ke20 and it turned his rear end into hard as a rock. i'm not sure where to find one though
    Jonathan
    Getting it rock hard is easy. Just add extra leaves.
    Short shocks are no needed, as that is no longer the thing that limits travel. Standard length or slightly shorter are going to work as well. You will be more interested in getting adjustable shocks, something that can match a very stiff spring.
    Getting it low is easy. Either lowering blocks and long U bolts. Or flip 1 or several leavs upsidedown.
    The hard bit... getting a combination that will not axle tramp under power, yet be soft enough to give some grip and ride, and shocks to match.
    Jonathan
    People always get axle tramp with leafs to start will. As a band-aid, they stiffen the pack with extra leafs. And adjustable shocks help a lot also. Adjusted right, not too stiff or too soft. Too stiff can be very bad.
    The proper way is to leave your soft leaf pack (which is probably stiff enough if you compare it to a coil), and use tramp rods. Guys in old Corollas doing rally often end up with a stockish soft leaf pack. But in rally I don't think you are allowed to add tramp rods, so one trick is to clamp the front of the leaf pack together tight, so this effectively acts as a control arm and resists tramp/twist. The rear half of the pack then does the springing. Another better way is to get rid of the leaf pack, and go to a single custom leaf. A guy in Melbourne will make this for you with your specs.
    With Rick Bates and the TRD HiLux ute trick show (whatever it's called), they actualy softened the springs all round. The HiLux rear leafs are too stiff to start with.
    Where are you located mate, I would be more than happy to show you the set up in my Panno if your in Melbourne.
    Mine have been custom made by Hitek in Lilydale, low and stiff.
    Someone mentioned flipping the WHOLE LOT, whilst this would get desired results, it seems it can be done in a E7 unless you cut part of the "spring mounts" so to speak, which would weaken them.
    Dont use lowering blocks if your intending on sliding it.
    Site Supporter Javal's Avatar
    Josho
    My recommendation is to either -
    a) if you can afford to have your car off the road for a few days, remove rear leaf springs, take to spring manufacturer and have them reset and an extra leaf added.
    b) if you can't afford to go without your car, go get some leaves from a picky wrecker and do the above.
    Reset + stiffened leaves > lowering blocks > flipping.
  1. ADELAIDE r32 seat suit on e7 rails/ wagon reset leafs
    By wagoooon in forum Car Parts For Sale
    Last Post: 18th August 2011, 06:55 PM
  2. flipping lips on 3 piece wheels.
    By Jono.C in forum General Topics (No Technical Questions)
    Last Post: 25th August 2010, 02:13 PM
  3. leaf springs,flipping??
    By john84ie in forum Technical - Questions
    Last Post: 25th November 2009, 03:24 PM
