Results 1 to 9 of 9
Thread: Ae86 and Ke70 hubs
    Scammer, DO NOT BUY FROM ME!
    Default Ae86 and Ke70 hubs
    are they the same?
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    No they are not, you need the correct ones for the strut.
    damn it!!!!
    anyone got an 86 hubs? haha
    c
    are t18 ones the same as 86?
    i think so...
    thinking the backing plates are different though??
    <img src=http://img114.imageshack.us/img114/3193/p1020339jk4.jpg border=0 alt= />
    Anyone get the License plate of that B& Hammer?
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by DAN-86 View Post
    i think so...
    I believe so - but i'm not 100%.
    As far as i'm aware TE72 and AE86 share the same stub axle - but the bolt pattern differs.
    So the hub should fit.
    Can anyone 100% certainly say that AE86 ADM hubs and Rotors fit on a T18 strut?
    All i can find is that the backing plate holes are different. but the 86 ones if redrilled will fit fine on T18 struts. then just bolt everything on.
    Anyone Confirm?
    Jonathan
    I think you can fit a AE86 hub on a KE70, AE71, KE30, TA22 or TE72 stub axle. I know this because they all run the same front wheel bearings.
    Senior Member kronix's Avatar
    Wade
    Stafford Heights
    i know this is bring up an old thread but i thought it might help. I have a ke70 with t-18 struts but i am thinking of buying bc coilovers for an ae86. I was just wondering if i could bolt my t-18 calipers and hubs etc straight to a ae86 strut/stub axle or will this not work? also what do people think about bc coil overs? any help would be greatful
  1. Replies: 1
    Last Post: 22nd March 2012, 08:49 PM
  2. ae86 hubs, brake brackets/brake disk shields the same as ke70 ones?
    By Sprinter Freak in forum Technical - Questions
    Last Post: 12th October 2011, 04:47 PM
  3. Replies: 2
    Last Post: 2nd May 2011, 08:48 PM
  4. ke70 hubs on ae86 struts
    Last Post: 7th April 2010, 04:40 PM
  5. RA60 Hubs and arms into a KE70
    By cazman in forum Technical - Questions
    Last Post: 28th April 2008, 09:42 PM
