No they are not, you need the correct ones for the strut.
are they the same?
damn it!!!!
anyone got an 86 hubs? haha
are t18 ones the same as 86?
i think so...
thinking the backing plates are different though??
Anyone get the License plate of that B& Hammer?
I believe so - but i'm not 100%.
As far as i'm aware TE72 and AE86 share the same stub axle - but the bolt pattern differs.
So the hub should fit.
Can anyone 100% certainly say that AE86 ADM hubs and Rotors fit on a T18 strut?
All i can find is that the backing plate holes are different. but the 86 ones if redrilled will fit fine on T18 struts. then just bolt everything on.
Anyone Confirm?
I think you can fit a AE86 hub on a KE70, AE71, KE30, TA22 or TE72 stub axle. I know this because they all run the same front wheel bearings.
i know this is bring up an old thread but i thought it might help. I have a ke70 with t-18 struts but i am thinking of buying bc coilovers for an ae86. I was just wondering if i could bolt my t-18 calipers and hubs etc straight to a ae86 strut/stub axle or will this not work? also what do people think about bc coil overs? any help would be greatful
