Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 11 to 20 of 102
Thread: s13 front coilovers into 86/*e7*
  1. #11
    性交を愛する marvis's Avatar
    Post a picture man.
    Quote Originally Posted by trikzlane View Post
    I love streeting, Lowdown cars and watching the world unwind by every word Marv types.
    Quote Originally Posted by keiichi View Post
    dont you get raped by the police everywhere you go?
  • #12
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    Default here some photos of the s13 front
    look how low its stupid how low it is. its not drivable dont no what to do?
ID:	2514   Click image for larger version.
ID:	2515   Click image for larger version.
ID:	2516   Click image for larger version.
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
  • #13
    Senior Member 45aken's Avatar
    Marko
    Dude you have a good 3 inches you can raise it up by.
    if you dont have the C spanners, the take out the coilover (you can do it in the car if you want, just easier taking it out)
    get a large flat head screw driver, put a rag around the end of it (only 1 or 2 folds) the then you'll have to press the end into the "steps" in the bottom rings and use a hammer to screw it down (this will unlock the seat).
    the use the screwdriver to tap the top seat up about 2 inches or so.
    and screw the lock ring back up and into the spring seat.
    It helps ALOT if you clean out the thread with a wire brush and wd40.
  • #14
    Troy
    Gisborn
    3more inches no way man no way i no how to raise coilovers up even when the car is jacked up on the hoist the wheel will only sag proberble 1 more inch. so confused
  • #15
    Marko
    Then raise it up 1". The spring seat is sitting quite low on the thread.
    are the springs captive when it jacked up?
    the s13 gear it low but even without adjustable bottom mounts you should still have it driveable.
  • #16
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    Quote Originally Posted by 45aken View Post
    i had some non base height adjustable coils in my car and had same height issues was realy low, the shocks are just short stroke and realy need height adjutable coils so the shocks dont max out on the top. my height adjustable hsd coils are wound right up and am only happy with the height now!!!
    also instead of the old toyota junk tie rod ends i would sujest using Buddy Parts motorsport tie rod ends they are awesomeness!!!
    AE86 THE BEST
  • #17
    Troy
    Gisborn
    thats what i think it is the shockers are to short stroke. there maxing out i got apexi coilovers do you guys thinnk this is the problem
  • #18
    User fantapants's Avatar
    Pat
    if you dont have base adjustable it will not work well. you can not raise the car much just using the spring perch and still have any sort of reasonable droop.
    that being said, yours isnt any lower than mine i think and i got a decent droop - springs arnt captive though and the stroke is ok BUT mine are BASE ADJUSTABLE ... thats the common theme
    06/07/2011
  • #19
    Eddie
    sa
    oh and by the pic im guessing those are 17s whick will have overall bigger diameter than 15s
    AE86 THE BEST
  • #20
    Marko
    Mine don't have an adjustable base, and it's a useable height.
    How high is your car off the ground?
    It doesn't look crazy low.
  • Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
    1. s13 front coilovers
      By shaunpierre in forum Nissan Parts For Sale / Wanted
      Last Post: 10th November 2012, 01:33 PM
    2. full s13 front conversion for 86/ke-coilovers and brakes
      Last Post: 14th May 2012, 10:42 AM
    3. WTB: S13 Front LCA's and S13 Coilovers. MONEY WAITING
      By luke641 in forum Cars or Parts Wanted
      Last Post: 15th February 2012, 01:13 PM
    4. S13 LCA's S13 front coilovers and AE86 rear coilovers
      By Brendan in forum Cars or Parts Wanted
      Last Post: 8th April 2010, 01:11 AM
    5. s13 front coilovers
      By 86adz in forum Cars or Parts Wanted
      Last Post: 15th December 2007, 11:14 AM
