Don't do it. that is all.
lol...
06/07/2011
ok well 14s are just fine for me thank you
my R32 calipers fit easily under 15's - i reckon u could go 14's with them
has anyone used or looked into using S14 knuckles for this conversion as im going r33 disc's and brakes. Doesnt look like the s14 hubs fit the s13 knuckles which i was told they do.
im going 5 stud with r33 brakes. everyone says s14 hubs will fit.
if they dont ill be planning to murder NS.com
hmmm funny cause thats where i got my info from and they dont fit, the wheel bearing on the s14 hubs is a few mm oversize for the s13 but i just used the s14 knuckles r33 calipers and rotors and s13 coilovers and it all fit fine . . . so far
gezz. i got s13 sr20det setup and i think its over kill. i dont know what lca i got but im using ae86 inner rack end and ra40 outers. works fine
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
so your using ra40 tie rod ends?
just have to make sure that the taper for the steering arm is the same.
i was under the impression that you had to use TRX bludbird tie rod ends in order for it to fit properly. i have trx ones in my car and they fit good.
you didnt notice the ra40 not fitting properly?
- Blaise Pascal
im pretty sure. ae86 innter rack with ra40 tie rod ends. the tie rod ends and is a funny bent arm. ill try to take pic when i have time
Pick up Sydney
Emails ignored
Texts ignored
Wankers abused
