Page 5 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 41 to 50 of 102
Thread: s13 front coilovers into 86/*e7*
  1. #41
    Moderator Sam-Q's Avatar
    Endeavour Hills
    should we have a mention to the downsides to this change in suspension? like what it does to your geometry
  2. #42
    matt
    vic
    knox
    thats what i want to know about!! i like the ease of this with the added advantage of big brake upgrade but, how badly does it mess with eveything else? i'm not a drifter, this mod might be great for drift but, might not be what i'm after.
    Marvis:
    We should do tandems. It will be like making love.
    And I will run into you.
  3. #43
    Endeavour Hills
    I never really looked into it much, but I want to find out, when I do I will post on here.
  4. #44
    User fantapants's Avatar
    Pat
    bump stear increased a little, not pover;ly much. the only real downside i have found has been an increase in effort at lock... this can be sorted a few different ways.
    all in all not a terrible idea like plenty here are keen to say it is
    06/07/2011
  5. #45
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    Default DIY coilover kit using s13 struts
    well before i proceed i need some opinions.
    I know alot of people reading the title would have a confused look on there face but just hear me out first
    Ok well doing the evorolla project, it needs good suspension and must have very good brakes as i plan on getting into some track work, not too seriously but you can never have enough brakes. This is why im very keen on sticking with my R33 front brake setup and 5 stud conversion all round using a Hilux rear end (staying 5 stud also) So alot of people are against the s13 front gear for reason's i can understand But the main problems i can see for this is that the aftermarket coilover's are simply way too low and the lca's are too long.
    So if i were to use a coilover kit and make them so they were alot higher than the aftermarket stuff and get some adjustable or even shorten the lca's would this still be such a bad direction to go??? It may seem like alot of effort but the main reason i want to do it this way is to keep my brakes ive already got becuase i cant see any other brake upgrade that pleases the eye and can be done on my budget.
    Not having ever done a coilover kit before and not knowing where to start my next question if no one can point out a serious fault in this proposition is how would i work out the height i need to mount the sleeve's to be able to achieve legal height for my car and have the adjustibility to go quite low for drift/track days.
    Also anything anyone can point out the do' and dont's when making your own coilover kit would be helpful to me and appreciated.
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
  6. #46
    Endeavour Hills
    J0RD0 I have moved the post from your thread into here to keep most of the S13 front end questions in one place
  7. #47
    Mar 2010
    i was wandering what steering arms you use if its going on an ae71
  8. #48
    Dave
    s13's dont have steering arms as such.
    the hub has the steering arms built in.
    if anyone is interested i will have a complete s13 setup for sale soon. just need to do a few exams and install my 86 gear.
    can test drive if they want before i put 86 stuff in.
    - Blaise Pascal
  9. #49
    Veteran biggo's Avatar
    Nick
    Noosa
    There seems to be a problem with your planning. I am fairly certain you CANNOT buy S13 inserts by them selves. They come as a complete strut.
    However, i did look into it a bit when i needed new inserts for my s13 coilovers. The best i found was that if i added another 15mm somewhere in the strut tube i could fit some ae92/st185 shocks in there. That project is still in the shed somewhere tho.
  10. #50
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    i personally think its easier n cheaper to buy s13 front coilovers as biggo stated im sure you cant buy shocks seperate
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
  1. s13 front coilovers
    By shaunpierre in forum Nissan Parts For Sale / Wanted
    Last Post: 10th November 2012, 01:33 PM
  2. full s13 front conversion for 86/ke-coilovers and brakes
    Last Post: 14th May 2012, 10:42 AM
  3. WTB: S13 Front LCA's and S13 Coilovers. MONEY WAITING
    By luke641 in forum Cars or Parts Wanted
    Last Post: 15th February 2012, 01:13 PM
  4. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
  5. s13 front coilovers
    By 86adz in forum Cars or Parts Wanted
    Last Post: 15th December 2007, 11:14 AM
