Page 9 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 81 to 90 of 102
Thread: s13 front coilovers into 86/*e7*
  1. #81
    Ryan
    NT
    Darwin
    Seeing as someone has already dug this thread up, another question. what are the options for Castor rods on S13 LCA's on an AE86? are the stock AE86 ones a good option?
    forgive me if i'm missing something, just haven't really seen much info around on this.
    Thanks.
  2. #82
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    if you use toyota castor rods you will have to redrill one of the holes on the lca. if you use nissan (aftermarket) castor rods you will have to modify, more extensively, the castor rod bracket.
  3. #83
    Apr 2011
    Gary
    Karalee
    fuck ! laptop died mid write up .
    for all your information this is a much simpler conversion than made out to be it requires minimal mods and does change the geometry but not in a negative way as all the die hard fans state . i will post a write up from my other computer when i get time .
    basically all you need is lock spacers +25 mm and slightly longer tie rod ends ke70 rod end taper matches s13 hub taper . simple .
    and if your going to run sr20 you can even use an sr cross member in a ke70 slot the rear holes and mod rack mounts or modify s13 power steer rack to suit ke70 .
    ill post in more detail later . sorry guys or pm me with questions
  4. #84
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    sway bar holes line up????
  5. #85
    Zac
    Sunnybanku
    barely, think they will be on an angle iirc, especially more so with the mx62 arms.
  6. #86
    Michael
    Crimebrook 2749
    also another one ill need to get another brake master cyclinder S13 ones dont need prop valve??? or am i wrong
  7. #87
    Zac
    Sunnybanku
    i dont think you need a new master cylinder, i have done this conversion on several coronas and a couple corollas all sr20 brakes standard master was fine.
  8. #88
    Michael
    Crimebrook 2749
    FUCK OATH!!!!!!!!! sick ass cheers
  9. #89
    Senior Member kaibeecee's Avatar
    Pete
    for those wondering about the castor rod dramas, i did a conversion using R33 GTR castor arms, where i sourced 5mm plate, bent it to a 'U' and drilled a hold through the top end and opposing ends and used an M12 & M14 bolts, tacked two 2mm thick washers to the end and copied an aftermarket 86 castor rod bracket essentially.
    IE:
    or you could ditch that crappy design and cut the guts out of the castor arm bracket and drill four holes and pay less for better castor arms that'll suit the car/allow for more lock (unlike the 86 ones.)
  10. #90
    Michael
    Crimebrook 2749
    alrighty, how did people go with brake likes, just used a longer??? braided line?
  1. s13 front coilovers
    By shaunpierre in forum Nissan Parts For Sale / Wanted
    Last Post: 10th November 2012, 01:33 PM
  2. full s13 front conversion for 86/ke-coilovers and brakes
    Last Post: 14th May 2012, 10:42 AM
  3. WTB: S13 Front LCA's and S13 Coilovers. MONEY WAITING
    By luke641 in forum Cars or Parts Wanted
    Last Post: 15th February 2012, 01:13 PM
  4. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
  5. s13 front coilovers
    By 86adz in forum Cars or Parts Wanted
    Last Post: 15th December 2007, 11:14 AM
