Page 1 of 17 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 161
Thread: S and T series diff info
    Veteran slide86's Avatar
    Huw
    Hills
    Default S and T series diff info
    to prevent people asking same questions all the time. if you know more stuff add it up. definate stuff too, i know some celica diffs will fit but there are differences that i don't know of for sure so i haven't put them in.
    S Series = ADM = no LSD available
    T Series = JDM or T18 + others = plenty of LSD's available (KAAZ, Cusco, TRD etc)
    S Series 8 bolts carrier to axle housing
    T Series 10 bolts carrier to axle housing
    S series = ADM AE86
    T series = JDM AE86, T18
    when fitting a T series diff you need a shorter rear tail shaft either out of a JDM 86 or a T18. the rear shaft for a t series is 20mm shorter than that of an s series
    ADM AE86 760mm, T18 740mm
    Ke70's have a borgwarner diff different to S and T series. both S and T series will bolt in but an s or t series tailshaft must be used.
    tailshaft and diff combo's (assuming you have fitted 4AC or 4AGE and using T50 box)
    AE86 + T series = ADM or JDM front half + T18 or JDM rear half
    KE70 + S series = ADM 86 or JDM 86 front half + ADM 86 rear half
    KE70 + T series = same as AE86 with T series
    AE71 + S series = same as KE70 with S series
    AE71 + T sereis = same as AE86 with T series
    Site Supporter Javal's Avatar
    Josho
    Factory fitted Differentials for xE7x and AE86
    KE70 Sedan, Wagon: Borg-Warner
    AE71 Sedan, Wagon: Borg-Warner
    KE70 Panel Van: S-series
    AE71 Panel Van: S-series
    TE72 Hatchback: T-series (ADM)
    Australian Domestic Market (herein referred to as 'ADM') AE86 Sprinter: S-series
    Japanese Domestic Market (herein referred to as 'JDM') AE86 Sprinter (Kouki): T-Series (Kouki)
    Japanese Domestic Market (herein referred to as 'JDM') AE86 Sprinter (Zenki): T-Series (Zenki)
    LSD Fitment
    Borg-Warner: No LSD's Available
    S-Series: No LSD's Available (although extremely rare factory ones are rumored)
    T-Series (all versions): LSD's Available from the factory, Commonly Available aftermarket (KAAZ, Cusco, TRD etc)
    F and G series: LSD's Available from the factory, some aftermarket LSD's available
    E-Series have no LSD's available.
    Different versions of the 'T-Series'
    JDM 'Kouki' (late model) T-Series:
    Slightly thicker axles compared to Zenki / ADM t-series (1~1.5mm)
    Larger bearings compared to Zenki / ADM t-series
    Disc Brake only (reference required)
    1410mm Width
    Mounts will line up to any xE7x / AE86
    JDM 'Zenki'(early model) T-Series
    Slightly skinnier axles compared to Kouki T-series
    Smaller bearings compared to Kouki T-series
    Disc OR Drum brake (Disc and drum brake have slightly different housings)
    1410mm Width
    ADM TE72 T-Series
    Axles / bearings / Housing same thickness as JDM zenki drum
    Drum brake only
    1410mm width
    ADM TA22 (post 73), RA23, RA28
    Axle thickness same as TE72 / JDM Zenki (however they are shorter)
    Drum brake only
    1365mm width
    Mounts will not line up properly with xE7x / AE86 mounts
    ADM RA40, RA60
    Axles thickness / length (splines unconfirmed) as TE72 / JDM Zenki
    Drum brake only
    1410mm width
    there is a minor difference in the measurements of the mounting points for the trailing arms and also the spring seats are slightly smaller also but factory xE7x, AE86 springs and trailing arms still bolt directly into this diff
    Suitable Toyota Differentials to transplant into your AE71 / AE86
    Moderate power:
    Assuming you are running a T-40 / T-50 gearbox.
    T series Differential from a JDM AE86 or ADM TE72, using the following tailshaft combo:
    AE86 Front
    TE72 Rear OR JDM AE86 Rear
    This is because the 'nose' of the carrier on a T-series is 20mm longer than that of an S-series
    Large power:
    E / F / G series, using a custom tailshaft + mounts
    Understanding Toyota Diff Codes / List of Toyota Differentials
    Toyota diff codes are broken down into several parts. As an example we'll use this one:
    T292
    This is then broken down into several parts, like this
    T/29/2
    The 1st digit denote the size of the Crownwheel
    The 2nd two digits denote the ratio of the differential
    The final digit denotes the number of pinion gears and if the differential is a factory Limited Slip Differential (LSD)
    The 'translator' for diff codes is as follows:
    First digit:
    A = 138mm
    B = 145mm
    C = 6.25"
    D = 6.62"
    E = 7.1"
    F = 7.5"
    G = 8"
    H = 9"
    J = 9.25"
    K = 9.5"
    L = 10.5"
    M = 12.5"
    N = 13.5"
    P = 14"
    Q = 12"
    R = 162mm
    S = 6.38"
    T = 6.7"
    U = 6"
    V = 10.6"
    W = 15.5"
    X = 142mm
    Y = 158mm
    Z = 202mm
    - no ring gear = FWD
    Second, third digits:
    01 = 3.30
    02 = 3.36
    03 = 3.545
    04 = 3.556
    05 = 3.70
    06 = 3.889
    07 = 3.90
    08 = 4.111
    09 = 4.222
    10 = 4.375
    11 = 4.444
    12 = 4.625
    13 = 4.79
    14 = 4.875
    15 = 5.125
    16 = 5.286
    17 = 5.60
    18 = 5.714
    19 = 5.833
    20 = 6.167
    21 = 6.667
    22 = 6.78
    23 = 6.833
    24 = 7.64
    25 = 4.556
    26 = 5.571
    27 = 3.364
    28 = 4.30
    29 = 4.10
    30 = 3.727
    31 = 3.909
    32 = 6.591 or 4.807
    33 = 7.503 or 5.583
    34 = 6.781 or 4.786
    35 = 7.636 or 5.60
    36 = 4.778
    37 = 3.583
    38 = 3.417
    39 = 3.154
    40 = 5.375
    41 = 3.308
    42 = 6.500
    43 = 3.550
    44 = 3.214
    45 = 3.533
    46 = 2.928
    47 = 3.944
    48 = 3.356
    49 = 3.729
    50 = 3.400
    51 = 3.736
    52 = 3.722
    53 = 3.250
    54 = 3.941
    55 = 3.333
    56 = 2.821
    57 = 4.058
    58 = 3.238
    59 = 3.234
    60 = 3.519
    61 = 2.724
    62 = 2.892
    63 = 2.655
    64 = 4.312
    65 = 3.837
    66 = 3.071
    67 = 3.526
    68 = 3.095
    69 = 4.176
    70 = 5.857
    71 = 2.962
    72 = 3.949
    73 = 4.285
    Fourth digit:
    2 = 2 pinions, not factory LSD
    3 = 2 pinions, yes factory LSD
    4 = 4 pinions, not factory LSD
    5 = 4 pinions, yes factory LSD
    Information sourced from: Toymods.org
    Thanks to Johnny Rochester and Just Half Steppin' for their contributions
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    a quick question for u gurus can i put in an ra40 center into my t series i think its a small axle version because all the sway bar mounts are welded on if any1 has some good info ill be appreciating it alot cheers mat
    the dyno pull to 300rwkw
    Andrew
    Quote Originally Posted by Javal View Post
    E / F / G series: LSD's Available from the factory, some aftermarket LSD's available
    E series LSD? You sure? Were 4X4 liteaces e series with LSD?
    Hilux diff. belong to which series? E, F or G?
    Huw
    Hills
    hilux is G series
    Josho
    Quote Originally Posted by pen15 View Post
    Yes.
    Use punctuation next time.
    Veteran slydar's Avatar
    Dimitri
    no e series lsd available.
    actually there is some really shit old holden "cone type" lsd you can make fit. but its crap.
    rear hilux diff is g (or A in later models with higher output, turbo diesel/4L ect) front is F.
    also ALL t series are small axle/zenki, except later model ae86 ('85.5-87)
    alex
    Just quickly. The KE70 wagon and sedan, both having the borg warner, are they the same bolt pattern? So an AE71 tailshaft will bolt up in my KE70 wagon?
    Josho
    Quote Originally Posted by YAZE View Post
    Yes.
    10char
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
