Page 11 of 17 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 101 to 110 of 161
Thread: S and T series diff info
  1. #101
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Unfortunately most of them are discontinued, so generally speaking, second hand is the only way.
    They aren't necessary per se, but they do help to make your brakes quieter.
  • #102
    May 2013
    South Australia
    ok...did a bit more diggin and found the following...
    I have compared a JDM AE86 Kouki housing to an RA40 one just yesterday. The results are as follows:
    Upper trailing arm spacing Lower trailing arm spacing Spring hat spacing.
    RA40 519mm 977mm 950mm
    ae86 494mm 980mm 930mm
    Note: the springs and upper trailing arms are not in ideal positions. Springs are quite elastic and should bridge and flex. The upper arms are very short and sit on a bit of a dodgy angle when flexed 13mm sideways. Id suggest an upper arm cut and weld mod to get it right.
    As for the springs:
    RA40 springs have a tight wound tapered end whereas ae86 ones have two fat ends. You will need RA40 springs for the diff end as that is the end where the spring tapers. Note coronas etc were very similar and springs will interchange.
    As for the trailing arms:
    The RA40 trailing arms are identical length units to AE86. Different bushes though. I have taken rough measurements and the cup diameter looks much the same.
    As for the forwards or backwards offset of the mounts and how they compare to one another:
    The RA has mounts 10mm further forward on the housing for all the suspension arms including the panhard rod. Their relative positions to each other are all much the same, but the RA diff will sit further back using the AE86 floorpan mounts and suspension arms.
    As for the panhard rod issue:
    Yes the ra40 panhard rod is a different length to an ae86. The pin to mount the rod is in a different position on the RA40 diff, making the rod about 50mm shorter than the AE86 one. Im not sure how the mount on the floorpan will compare from the RA to AE86. I have not checked. Use an adjustable rod.
    As for the tailshaft:
    Im not sure at this stage about whether you can use the RA40 rear section or not. I measured the length from face to face on the ra40 one, it is 760mm. In my opinion if it is about 10mm longer than a t18 rear section then the RA40 rear tailshaft section will be fine, and will effectively lengthen your wheelbase by 10mm, when used in an AE86. This could be why you have to force it together when using a t18 rear section, since the trailing arms are all the same length from RA40 to AE86, but the RA40 diff is sitting further back due to its mounts being further forwards on the housing.
    SOMEONE WITH A T18/JDM TAILSHAFT SITTING AROUND PLEASE MEASURE THE REAR SECTION. My guess is 750mm.
    As for the bushes:
    The centre bolt is larger on the ra40 bushes/diff. The outer bush cup size is the same on both cars, according to my measurements. Note, I have not actually fitted it yet, but my assumption is I would use an RA40 bush one end, and aa AE86 one the other. Look to the info above for real practical advice.
    As for the Swaybar:
    The RA40 diff I looked at had no mounts on it. The JDM one does. You will need a welder.
    As for the Brakes.
    Most RA40 diffs have drums on them. Not sure of their size but I suspect they are slightly larger drums than AE86. Only RA40GTs came out with factory lsd and disc brakes. That diff pictured is very rare and expensive. Don't get your hopes up of finding better than a drum braked, open centre 4.1 ratio.
    The width from one mounting face to another is 1410mm on the RA40 diff. Not sure if a JDM diff is the same as I was comparing a housing to a complete diff. Hope this settles a few bets.
  • #103
    West
    You can jump onto us ebay and search for ae86 brake pad fitting kit and you should pull up the set of clips for the rear caliper.
  • #104
    Oct 2010
    Dogan
    Tulla
    I had a RA40 T series diff in my old AE86.
    I used the standard ae86 trailing arms, the ra40 handbrake cables, t18 rear half of the tailshaft and a whiteline adjustable panhard rod.
    The whole diff pretty much bolted right up, I didn't have much trouble with the arms being on any strong angles or anything. Although you could see how the trailing arm brackets on the diff are in slightly different locations than they are on a T18 T series. Thats also the reason why the pinion will be slightly pointing up compared to standard.
    The spring seats are definitely smaller but it's not so small that your springs would fall through or anything. If you're worried about the chance of the springs falling through then forget the idea of putting a cheap RA40 T series diff into your car and fork out whatever you need to for a T18 T series or an AE86 item.
    Oh and all T series centres are interchangeable between each other, it doesnt matter if one is out of an ra40 or a t18 or an ae86. I had a T18 centre with a TRD 2 way in my ra40 t-series.
    FYI when putting a TRD 2 way lsd into a ra40 t series you need to shave roughly 5mm off the edge of the axle to get it all to fit.
  • #105
    Lawrence
    Wollongong
    Quote Originally Posted by dogan View Post
    Wrong.
    The carrier and crown wheel & pinion are usually interchangeable, but there are 2 different diameter axles depending on the year of manufacture. Later AE86's had larger axles, October 1985 they switched to a larger size. All centres before that were interchangeable.
  • #106
    Veteran anastasios's Avatar
    Taz
    Earlwood
    will kouki JDM handbrake cables disc brake work with my AE71?
  • #107
    May 2013
    South Australia
    with the use of spacers or a jdm ae86 front half cable you will be fine
  • #108
    Taz
    Earlwood
    what do you mean front half? the bit which the separate cables hook into?
    Sent from my GT-I9100T using Motorculture mobile app
  • #109
    Lawrence
    Wollongong
    I ended up using the disc brake liners but replacing the inner wire. The cable clamps on the body are in different locations to an AE86, so when the cables are installed they're too short.
    I don't know about the AE86 front cable section, but I its plausible.
  • #110
    May 2013
    South Australia
    yes, the cable that attaches to the handbrake lever itself...it is shorter in the jdm 86, and t18...
  • Page 11 of 17 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
    1. F series Diff info + Discussion
      By Konakid in forum Technical - Articles
      Last Post: 30th January 2018, 07:31 AM
    2. G series Diff info + Discussion
      By PRIMRK in forum Technical - Articles
      Last Post: 25th July 2014, 02:41 PM
    3. info on fitting rear 86 calipers to series 1 T18 diff
      Last Post: 29th April 2012, 02:46 AM
    4. Info on F series diff ratios above 4.3
    5. prize for this answer! s series diff info
      By styler in forum Technical - Questions
      Last Post: 28th November 2006, 01:50 PM
