Page 7 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 61 to 70 of 161
Thread: S and T series diff info
  1. #61
    Junior Member JAM533's Avatar
    May 2011
    Sunshine Coast
    ok measured my axle's today, diameter of 23.8mm, so from what i know this is zenki. if someone can confirm this it'd be a huge help =)
  • #62
    turkey
    sa
    southern hills
    Quote Originally Posted by ae_drift_86 View Post
    what defines "high power", as in how much can a t series handle....
    also, what brakes, the axles? surely cant strip the teeth of the crown wheel and pinion..?
    im running a 4agte and it blew the crown wheel and pinion(no teeth left on the pinion) but it lasted a fair while. there strong but not bullet proof.
  • #63
    Mar 2010
    Penrith
    Going by the list on page 1, an S315 diff as per my VIN plate would be a LSD?
  • #64
    Senior Member Patric's Avatar
    Patric
    Enfield
    A Majority of the diff info you want can be found here. http://web.archive.org/web/200901221...o/newcodes.htm Thanks wayback machine.
    JAM533: Axles size info found here http://www.club4ag.com/faq_and_tech_...0Differentials
    Silver 86 Trueno Hatch.
    AE86 4age gear for sale - http://www.ae86drivingclub.com.au/fo...eats-Ae86-gear
    Side intrusion bars for your import - http://www.ae86drivingclub.com.au/fo...our-JDM-import
  • #65
    Jun 2009
    Ollie
    I have been looking all morning, but I cant find what ratio my ke70 is. Its an 1982 manual wagon, k-50 (5 speed). Some people say that its different to the ae71 borgie's, and it differs between 4 and 5 speed ke70 boxes.
    Can anyone shed any light?
  • #66
    Patric
    Enfield
    Have a look at the code on plate on your firewall. http://web.archive.org/web/200901300...tepho/diff.htm
    Check cose at above link. It will tell you ratio.
  • #67
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    Code should be 282... For a 4.3, 2pinion open centre, small chance it could have a 4.1, but I doubt it
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  • #68
    Senior Member odessy's Avatar
    Blake
    Qld
    Bris
    Would like to confirm that a t series from an ra60 is a straight bolt in swap? Think I have found one I can pull the diff out of, do I need the handbrake cable or anything else from it?
  • #69
    Veteran johl's Avatar
    Johl
    yes i pulled one out at the wreckers and used it. there are rumours being spread that the trailing arms dont line up or some shit but that is entirely false as i have done it. as for handbrake cables i cant remember which ones i used but better grab them just incase
  • #70
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    They line up but aren't ra60 a wider diff opposed to a t18 item?
  • Page 7 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
    1. F series Diff info + Discussion
      By Konakid in forum Technical - Articles
      Last Post: 2nd October 2017, 12:18 PM
    2. G series Diff info + Discussion
      By PRIMRK in forum Technical - Articles
      Last Post: 25th July 2014, 02:41 PM
    3. info on fitting rear 86 calipers to series 1 T18 diff
      Last Post: 29th April 2012, 02:46 AM
    4. Info on F series diff ratios above 4.3
    5. prize for this answer! s series diff info
      By styler in forum Technical - Questions
      Last Post: 28th November 2006, 01:50 PM
