Results 1 to 10 of 13
Thread: Trailing Arm Troubles
    Veteran svenmate's Avatar
    Svenbot
    East
    Default Trailing Arm Troubles
    Hey everybody,
    I thought a rose-jointed 4link setup would be easy to install but I'm having a bit of trouble putting them in. Sad face.
    Firstly, the lower-arm diff bush is turning on the tube rather than the bolt turning within the bush. So the 19mm bolt won't come out. Any idea/tips on how I can remove it? I tried bashing it out but it's pretty wedged in there.
    The pic below shows the successful arm that came out but the tube was also pretty loose.
    Secondly, the 19mm bolt has a larger diameter than the 17mm and so it won't fit in my link. Is it ok to remove the spacer and have the bolt that fits loose within the link? Pics below.
    Any tips/suggestions would help a lot.
    Thanks
    Svenmate
    AE71 Build Thread
    Apr 2010
    add heat and wd40 i know it will smoke up but the neighbors will think you are just doing another burnout.also hammer when it is hot.have you got the car high enough to get a good hammer swing?also i dont thuink a loose bolt in the link is good
    Svenbot
    East
    Yeah was thinking of melting bush then hammer again.
    Anyone got an idea on the spacer issue? I'm thinking of just finding another 17mm bolt from somewhere..
    AE71 Build Thread
    Moderator Sam-Q's Avatar
    Endeavour Hills
    ok I am a bit confused, being a KE70 it should have an M12 bolt with a 17mm head, whats with the 19?
    Jul 2010
    a loose bolt would defeat the purpose of rose joints and bushes :/
    make sure you track down the right size.
    Svenbot
    East
    Diff is from a celica. I just remembered. Damn.
    Ok so I'll have to find/buy some 17mms then. Woot.
    Thanks for the help, fellas.
    Will let you know if things change
    AE71 Build Thread
    Veteran timbo's Avatar
    Tim?
    Wild West
    i had similar issues with my traction brackets. standard toyota stuff are 17mm as sam said. the bolts that came with the traction bracket are 19mm and seem plated thus a little thicker. i ended up enlarging the holes in the mounts only slights and used a shit load of wd40 to get them in, just don't force them, you will know if they will fit or not.
    Endeavour Hills
    either that or you use the original 12mm (17) and I machine you a spacer
    Svenbot
    East
    I'm yet to try it out due to full time study. Will post my results later in the week. Thanks, men.
    AE71 Build Thread
    Svenbot
    East
    Hell yeah. Just cut the sucker. Best feeling ever!
    AE71 Build Thread
  1. length of trailing arm bolt
    Last Post: 31st May 2010, 08:28 PM
  2. Trailing arm bush options
    By starni_boy in forum Technical - Questions
    Last Post: 5th April 2010, 01:44 PM
  3. Stiffer trailing arm bushes ?
    By fixeruperer in forum Technical - Questions
    Last Post: 28th October 2009, 10:10 PM
  4. HELP upper trailing arm
    By i2obert in forum Technical - Questions
    Last Post: 10th October 2009, 01:48 PM
  5. AE86 Trailing Arm Bush Sizes ??
    By Patrini in forum Technical - Questions
    Last Post: 29th April 2009, 10:37 PM
Tags for this Thread
