Results 1 to 10 of 18
Thread: 3sge Clutches
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Default 3sge Clutches
    So i'm trying to get myself the correct exedy clutch for my new motor.
    Beams 3sge with W-57 gearbox.
    I Got a price from the supplier at work for the proper Altezza clutch, and they definately stuffed up because the price for the clutch kit (no flywheel) was $1900.
    So now i'm trying to get a part number from an equivalent car that will still work with my gearbox engine combo.
    My flywheel will take up to a 230mm clutch, but most of them seem to be only 225, (not that this is probably very critical)
    So does anyone have any ideas on models that will work for my application?
    Andy
    Dec 2009
    Andrew
    California
    Nothern
    USA
    I took my flywheel down to the parts store and verified one kit that works here in the states:
    During my research I looked into a bunch of different models from toyota and have found a couple that the dimensions do fit.
    I literally took my dual mass with me to the parts store earlier today to verify the pressure plate would fit on one of them, as they had it in stock. The one I tried is from a MA46/47 Celica-Supra with 4M-E/5M-E engines. Which is also the same part used on 81-88 Pickups with a 22-RE and the 85-88 Van with 3Y-E/4Y-E.
    Dimensions Match: 225mm disc, 29.8mm dia x 21T.
    AND the pressure plate fits the flywheel.
    Here it is:
    Sachs Clutch Part Number: KF62801
    Part Detail at CSK Auto
    I built a reference sheet for exedy clutches and I think this one should work for you: TYK-6311 (also available as heavy duty/cushion button - TYK-6311 HDCB)
    Just add a double row spigot bearing: 5201-2RS or equivelant
    Andrew
    Andy
    Adelaide Hills
    what model car is the TYK-6311 from?
    the MA46/47? because we didn't get that in aus to my knowlege
    *EDIT* Looks like it's anything with a w-series box in it, but the spline size is different to what is listed for the altezza, 28.9mm compared to 29.8 on the altezza
    Andy
  • #4
    Dec 2009
    Andrew
    California
    Nothern
    USA
    WTH! When I made my sheet it showed 29.8
    Hmm... just took a quick browse the exedy.com.au and even on cars I KNOW have a W5x it shows the 28.9 instead of 29.8.
    Typo?
    Yeah, that clutch fits Tarago/Hiace with 3/4y's, hilux with 3y/4y/22r's, MX7x's, Soarer's etc.
    Andrew
  • #5
    Andy
    Adelaide Hills
    quite possibly, seeing as they didn't even have the specific altezza listing in the price sheet when i rang about it.
    is there a flywheel diameter that needs to be worked out? the only other problem i can see is that they don't make a hyper single clutch kit for the TYK-6311, which is the one i need.
    Andy
  • #6
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Hyper single kit for Altezza = TH03SD
    http://www.exedy-racing.com/pro/fitt...a/alte_hy.html
    Parts in TH03SD:
    Clutch cover = CH11S
    Disc = DH07D
    http://www.exedy-racing.com/pro/repair_1.html#hs
    Problem is, you need a hypersingle flywheel... do you have one?
    The other one will work with a stock flywheel, or any aftermarket replacement for an altezza from japan. If using a W5x.
    Andrew
  • #7
    Andy
    Adelaide Hills
    don't have a hyper single flywheel,
    just checked against xtreme clutches listings,
    they list the celica and altezza at the same size shaft - 29mm
    whereas exedy have it as
    celica, supra, tarago (anything with a w series box) as 28.9mm
    altezza, and a few of the other possible ones - 29.8mm
    so now i don't know what to go off... i thought they were the same size and so did the guy at xtreme when i spoke to him.
    having a look at stuff now i think a cushioned button should work, but not sure if they are comparable to the xtreme ones. (hopefully the springs don't fall out of the clutch plate like the xtreme ones do)
    Andy
  • #8
    Dec 2009
    Andrew
    California
    Nothern
    USA
    If you want to know if they're the same, and why I know it's a typo. Take a look at the clutch alignment tool... they're the same part #.
    Altezza J160 & W55-59 have the same input & output spline IIRC. I don't have a J160 to compare anymore, but at one point I did.
    Andrew
  • #9
    Andy
    Adelaide Hills
    ok so that clears that up.
    now will the flywheel size be the same overall diameter if the clutch sizes are the same?
    or do they vary?
    Andy
  • #10
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Flywheel size is usually the same O.D. size if it has the same size disc. I think Toyota tends to use the same flywheel ring gear with the same size disc.
    What flywheel do you plan on using/already have?
    Andrew
  • Page 1 of 2 1 2 LastLast
    1. Xtreme Clutches
      By sundee in forum Spirited Drive
      Last Post: 10th May 2012, 12:32 AM
    2. clutches
      By stuartgze in forum Technical - Questions
      Last Post: 8th August 2009, 01:52 AM
    3. 4agte clutches
      By reecegze in forum General Topics (No Technical Questions)
      Last Post: 15th May 2008, 12:34 PM
    4. sprinter clutches
      By the_sleepa in forum Technical - Questions
      Last Post: 30th July 2005, 05:43 PM
