Results 1 to 5 of 5
Thread: Brake boosters smaller options?
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default Brake boosters smaller options?
    Does anyone know of a suitable brake booster (that is a good deal smaller than the 86 one) that can be used when using a bigger master (r32 ect) for an FC caliper upgrade....?
    (this is to give additional clearance for the way I'm going to run my quads)
    Also I have noticed that a few people have mentioned running no booster altogether.. what is the go with that set - up?
    Niz.
    BENT MECHANIX - Garage 20:
    there all about the same size other option is race peddal box = win clears it all up for about $500
    Niz
    South~Slide Briz
    damn that sucks... I guess I will just work around it...
    Can anyone comment on running no booster?
  • #4
    Senior Member *E7*'s Avatar
    Dave
    Eastern Melb.
    you could run a remote booster. you can put it anywhere, and run your brake lines in and out of it, but it will only assist front or back, not both.
    use a vh44 booster (common out of older valiants)
  • #5
    Senior Member hilux05's Avatar
    Richie
    Sunshine Coast
    im pretty sure LRS said something ke35 boosters are smaller in dia.. not too sure if the r32 will bolt up to it but..
  • Similar Threads
    1. rear brake options on KE70
      By 20v ae71 in forum Technical - Questions
      Last Post: 27th May 2011, 06:36 PM
    2. SYD : AE86 brake options
      By evil86 in forum Cars or Parts Wanted
      Last Post: 29th June 2010, 07:39 AM
    3. brake booster - removing, smaller one, other ideas
      By h1_roll4 in forum Technical - Articles
      Last Post: 11th January 2009, 10:58 PM
    4. Rear Brake options
      By TUF 086 in forum Technical - Questions
      Last Post: 15th August 2007, 05:07 PM
    5. Brake Boosters
      By RolandGTV85 in forum Technical - Questions
      Last Post: 23rd May 2006, 06:02 AM
