Results 1 to 9 of 9
Thread: T-18 strut to AE86 coilovers
    Senior Member stouty's Avatar
    Leigh
    Forster
    Default T-18 strut to AE86 coilovers
    I want to do a full brake and strut conversion as there is no brake upgrades available for the T-18 breaks.
    What is needed to go from T-18 to AE86.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    Veteran slydar's Avatar
    Dimitri
    have you asked dave if he can make his FC caliper adapters suit t18 struts? would have thought it would be at most just changing the location of a few bolt holes.
    Leigh
    Forster
    Hadnt thought of that but i have 14" rims and dont really want to spend $1000 on brake upgrade. Was just looking at getting some better pads and vented slotted discs.
    Grip TE72
    4AGE AE86
    the only thing you need to change is the strut top...you have the Cusco T18 tops yeh?
    steering knuckle is the same...
    Dimitri
    might be worth check to see if you ae86 brakes will fit. i just cant imagine it being terribly difficult to fit them. might just need some holes drilled. im fairly sure everythiing else is the same.
    also 4AGE AE86 - ae86, ke70 and te72 use the same strut top bolt pattern.
    Scammer, DO NOT BUY FROM ME!
    gilly sold me some t-18 struts that had ae86 brakes on them ages ago, so yeh pretty sure it wont be hard to make 86 brakes fit
    4AGE AE86
    Quote Originally Posted by slydar View Post
    no they dont....series 2 t18 does, series 1 t18 is different...and stouty has a s1
    you also cant run AE86 camber tops properly in series 1 t18 strut top holes as they are round not oval in shape, so they cause the top to be un-adjustable...
    as for fitting sprinter brakes to T18 struts, it is a simple measure, mark out and drill operation...
    Stouty: can you get you hands on a pair of sprinter backing plates? if so, lay the t18 ones over the top of them and mark the holes, then just drill them out...the hubs are the same
    Site Supporter Javal's Avatar
    Josho
    This is not entirely correct.
    S1 TE71/TE72 uses a different bolt pattern. A few select people know which cambertop will fit. ]
    S2 TE71/TE72 uses the ae86 top.
    Quote Originally Posted by AJPS View Post
    stouty
    i can drill the adapters differently if you send me your struts
    You're a superhero like that.
    Leigh
    Forster
    Yes i have Cusco TE71 cabmer tops that Dave from AJPS and Chris ( Just Half Steppin ) chased down for me. So i might look in to just changing the brakes then doesnt sound like it will be to hard.
    4AGE AE86 idea sounds the best just got to get the brakes and sprinter backing plates.
    Cheers Dave but i just dont have the money to do the FC caliper upgrade.
    Grip TE72
  1. AE86 Coilovers and Strut Brace
    By ruffpower in forum Car Parts For Sale
    Last Post: 22nd August 2012, 11:28 PM
  2. Dampers for strut converted coilovers.
    By odessy in forum Technical - Questions
    Last Post: 31st October 2011, 08:55 PM
  3. Replies: 42
    Last Post: 1st March 2011, 01:34 PM
  4. Replies: 2
    Last Post: 12th January 2011, 09:29 PM
  5. wtb t-18 rhf strut
    By kronix in forum Cars or Parts Wanted
    Last Post: 29th June 2009, 08:16 PM
