Measurement of face of disc to face of hub? Thickness of said disc?
nah i dont ATM, if i come across some ill try them out, their is not much overhang, 03's might be ok.... but wont know until i can test fit.
am also looking at making up a single calliper version of this for those who want it for circuit apps or those not needing handbrake.
I got nothing.
Face of disc to face of hub?...... the rotor mounting face is approx 7mm thick if thats what your asking?
Rotors are 296mm x 18mm and vented
The total thickness of the disc, widest measurment.
I got nothing.
Any chance of a handbrake caliper that is not hydraulic?
no offence is your going to do all thsi work why would you bother keeping a cable hand brake??
Nah no chance, this is a performance upgrade, aimed at "track use" if you can find a cable type caliper that fits go for it. But you would have to buy the brackets first
so how many $$$$$$$$$$$$$$$$ is the kit
sick stuff joel. most interested. i currently have s13 front end setup on my 86, would these rear outbreak the fronts? any chance taht i could use sr20 rotors instead of r series
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
you could just use a bias control if your worried, or you can upgrade to R series brakes on the front, if your running S13 gear.
Kit is designed for 296mm rotors, S nissan rears are only about 260mm.
brackets will be tested early in the new year.
new pics up page 1
