Car: street and track ae86
Car use (e.g grip/drift): dorifto
Front Struts: ae86 spring on shock
Spring Rate/ Free Height: 8kg / 210mm
Inserts (brand/model): kyb agx
LCA's: standard
RCA's (size if you have them): 35mm -ve
Strut Tops: cusco
Front Sway Bar: adjustable whiteline
Castor Arms: standard
Rear Springs: 6kg / 220mm
Rear Shocks: kyb agx
Panhard Rod: adjustable whiteline
4 Link:
Bracing: ultra racing 4 point underbody brace and front brace, front and rear strut braces, ajps harness brace thingy
Pro's: very firm and direct
Con's: just a little too firm for street but is bearable
Extra Comments:
all bushes are urethane in the car aswell as all new steering components which makes the suspension feel better.
also have trd solid engine mounts and gearbox mounts so the car is quite firm all over
Car: track only 86
Front Struts: greddy coilovers
Inserts (brand/model): greddy
LCA's: standard
RCA's (size if you have them): 40mm
Strut Tops: greddy
Rear Springs: 6kg
Rear Shocks: greddy
4 Link:
Bracing: ultra racing 4 point underbody brace and front brace, front and rear strut braces, ajps harness brace thingy rollcage and full spotwelded chassis
Pro's: not sure cause havent driven it yet but im sure it will be the bomb
Con's:
Extra Comments: again all bushes are urethane
