Page 1 of 16 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 152
Thread: Your Suspension Setup
    Scammer, DO NOT BUY FROM ME!
    Default Your Suspension Setup
    TO REMOVE ADS, PLEASE
    REGISTER OR SIGN IN
    OK thought we could all post up what suspension setups we have and how we would rate them, the pro's and con's of your setup and what your setup is designed.
    Fill this lil template out and post it
    Car:
    Car use (e.g grip/drift):
    Front Struts:
    Spring Rate/ Free Height:
    Inserts (brand/model):
    LCA's:
    RCA's (size if you have them):
    Strut Tops:
    Front Sway Bar:
    Castor Arms:
    Rear Springs:
    Rear Shocks:
    Panhard Rod:
    4 Link:
    Bracing:
    Pro's:
    Con's:
    Extra Comments:
    Look forward to seeing what everyone has!!
  • #2
    Henry
    Eastern
    Car: AE71
    Car use (e.g grip/drift): Both
    Front Struts: AE86 coilover
    Spring Rate/ Free Height: 8kg, 200mm
    Inserts (brand/model): KYB Excel G SS
    LCA's: XT130
    RCA's (size if you have them): 35mm
    Strut Tops: Cusco
    Rear Springs: 200mm 6KG
    Rear Shocks: KYB Excel G SS
    Pro's: stiff, predictable, camber adjustment, track increase through lca's.
    Con's: Shocks not stiff enough, needs rear traction brackets.
    [B]
    RT142 Estate.
    AJPS.
  • #3
    Veteran Robo86's Avatar
    Rob
    Car: AE86 Coupe.
    Car use: Drift.
    Front Struts: AE86 Coil over.
    Spring Rate/ Free Height: 8.5kg, 200mm.
    Inserts (brand/model): AE92 TRD Yellow Insert.
    LCA's: XT130 (Fresh bushes/joints)
    RCA's (size if you have them): 45mm.
    Strut Tops: Cusco camber tops.
    I run custom coilovers in the rear, trd shock with sleve welded on.
    Rear Springs: 7kg spring
    Rear Shocks: TRD Blue 8 way adjust.
    Pro's: Stiff & Predictable...love it
    Con's: Anger can come into play when running such rates on brisbane roads.
    Extra Comments:
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  • #4
    Veteran johl's Avatar
    Johl
    Car:ke70
    Car use (e.g grip/drift): drift
    Front Struts:ae86
    Spring Rate/ Free Height: 6kg 200mm
    Inserts (brand/model):kyb exel g
    LCA's:xt130
    Strut Tops:cusco
    Rear Springs:ajps 230mm 4.5kg
    Rear Shocks:kyb exel g
    Pro's:nice ride for a daily yet stiff enough for track duties
    Con's:sites higher than i would like. would like someadjustability in the shocks as well as slightly harder springs, but then it would be bad on the streets so i have to compromise
    Extra Comments:cusco swaybars front and rear, adj 4 link, adj panhard
  • #5
    Sly
    Qld
    Car:ae86
    Car use (e.g grip/drift):drift
    Front Struts:custom coilover
    Spring Rate/ Free Height:8kg/200mm
    Inserts (brand/model):agx 4-way
    LCA's:standard
    RCA's (size if you have them):40mm
    Strut Tops:tein cambertops/ps arms
    Rear Springs:gaz coilover/6kg
    Rear Shocks:
    Pro's:stiff
    Con's:stiff
  • #6
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    Car: ADM AE86
    Car use (e.g grip/drift): drift/weekend car
    Front Struts: AE86 converted to coilover
    Spring Rate/ Free Height: 8 kg/230mm
    Inserts (brand/model): SW20 KYB AGX
    LCA's: Stock
    RCA's (size if you have them): Nope but have NRCAs (t3)
    Strut Tops: T3
    Rear Springs: AU2 XR8 IRS cut to 210mm
    Rear Shocks: KYB Sierra
    Pro's: adjustability, stiff, good for drift
    Con's:not so good for daily, to stiff on bumpy roads
  • #7
    Davey & Riki-lee
    South Australia
    Seaford SA
    Car: KE70
    Car use (e.g grip/drift): Drift
    Front Struts: AE86 AJPS coilovers
    Spring Rate/ Free Height: 7KG/Unknown
    Inserts (brand/model): KYB/short strokes
    LCA's: XT130 Corona
    RCA's: 40mm AJPS
    Strut Tops:
    Rear Springs: AJPS 6kg 215mm
    Rear Shocks: random toyota ones from a 4wd?
    Extra Comments:
    Not finished
    Our introduction - Click here
  • #8
    Veteran blair's Avatar
    Blair
    Sheldon
    Car: Aus AE86
    Car use: Drift.
    Spring Rate/ Free Height: 8kg, 220mm.
    Inserts: AE92 TRD Yellow Insert.
    LCA's: XT130
    RCA's : 40mm.
    Rear Springs: 6kg spring 200mm.
    Pro's: Stiff enough for the track. adjustability.
    Con's: I live halway in the bush so the roads really suck + my DRIVEWAY! (tar laid down soon swoit!)
    Extra Comments:only other thing i wil be upgrading is sway bars and bushes all round.
  • #9
    Moderator Frak's Avatar
    Jamie
    Car: AE86
    Use: Circuit
    Front struts: Ae86 coilover 60mm cut
    Spring rate: 380lb/in
    Inserts: TRD blue 5 way
    LCA's: Cusco Fabricated(not standard lca with rod end on inner)
    RCA's: 45mm
    Castor Rods: Cusco
    Strut Tops: Revolver Racing
    Rear springs: 225lb/in
    Shocks: TRD blue 8 way
    Coil over conversion using 2inch OD spring
    Equal length upper/lower arm with Cusco arms, genuine N2 TRD upper arm box section
    Cusco Panhard rod
    Cusco roll centre adj
    Nagisa Auto traction brackets
    Pro's : nicely balanced, very predictable, incredibly neutral.
    Con's : None, I'm very happy with this set up.
    Hachiroku since 1994
  • #10
    4AGE AE86
    REGISTER OR SIGN IN
    Car: AE86
    Front Struts: AE86 Stage 3 Coilovers
    Spring Rate/ Free Height: 8kg/200mm
    Inserts (brand/model): AGX 4 way
    LCA's: Stock
    RCA's (size if you have them): 40mm
    Strut Tops: Kei Office
    Rear Springs: 6kg 215mm
    Pro's: stiff enough to hold good grip, still easily soft enough for daily use
    Con's: need a wheel alignment....
    Extra Comments: still plenty of parts sitting in a box waiting to go in...
  • Page 1 of 16 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    1. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
      By sleeper_13 in forum Car Parts For Sale
      Last Post: 25th July 2012, 01:06 AM
    2. Need Help With Suspension Setup
      By ArbPotatoes in forum Technical - Questions
      Last Post: 30th June 2009, 10:51 PM
    3. ke70 suspension setup
      By biggo in forum Car Parts For Sale
      Last Post: 9th January 2008, 12:16 PM
    4. WTB::: suspension setup
      By winslow in forum Cars or Parts Wanted
      Last Post: 16th August 2007, 04:53 PM
    5. suspension setup
      By AE86_4life in forum Technical - Questions
      Last Post: 1st November 2006, 08:43 PM
