Results 1 to 8 of 8
Thread: Fuel leak
    Member Corona w/ Lemon's Avatar
    Truck
    South
    Default Fuel leak
    Hey,
    I seem to be leaking fuel from the petrol tank Ive inspected it and it looks like there was some sort of hole in it thats been patched up
    Any ideas to stop the leak until i have enough time to change tanks? and has anyone changed there tanks before?
    Any help is greatly appreciated.
    Veteran slide86's Avatar
    Huw
    Hills
    get some of that kneed it....or steel putty or what ever it is.
    you will be able to seal up the hole temporarily until you can get the tank out.
    Member phoenix's Avatar
    Nick
    Quick Steel is one that springs to mind and is easily available from auto parts stores
    Formerly 86 Nick
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by phoenix View Post
    Used that stuff too, it works pretty well... although I haven't tried it patch a fuel tank.
    Site Supporter Javal's Avatar
    Josho
    Quicksteel would probably be the best.
    Changing the tank isn't that hard.
    Nick
    Quote Originally Posted by Golberg View Post
    we used it to "fix" a corossion hole in the engine block from the water jacket over the top into the combustion chamber in a mitsi magna.
    The car is still going on that engine 4 years later
    If it can do that which shocked the shit outta me then it should be fine on the tank just make sure you clean and sand the area around the hole to get a good seal and to make sure it sticks
    Formerly 86 Nick
    Truck
    South
    Tried the quick steel stuff on an exhaust hole i had in the muffler and it worked well but it hasnt completely stopped my fuel leak, it just slowed it down. Im going to buy another one and put it on the tank and if that doesnt help i guess ill change the tank sooner rather than later.
    Thanks for the help.
    Truck
    South
    I bought another Quick Steel and its still leaking fuel. Im just going to change the tank over as i think it'll be easier in the long run.
    Also, the Quick Steel come off of my muffler while i was driving it. Maybe the muffler gets too hot?
    Thanks any way for the help.
  1. Sprung a leak, Capt'n!!
    By Deeken in forum Technical - Questions
    Last Post: 1st March 2012, 01:37 PM
  2. i think i have a boost leak
    By fergie in forum Technical - Questions
    Last Post: 21st February 2012, 06:46 PM
  3. oil leak
    By Fozz in forum Technical - Questions
    Last Post: 6th April 2009, 05:56 PM
  4. Fuel Tank Leak
    By aimre in forum Technical - Questions
    Last Post: 2nd May 2008, 11:18 PM
  5. Dizzy oil leak
    By wide s13 in forum Technical - Questions
    Last Post: 26th May 2006, 10:02 AM
